-RYknow
- September 20, 2012
- Claremont, nh
- 2003 Mercury Mountaineer
Hey guys. I posted awhile back about an issue we're having with our mountaineer. This is a follow up with more information.
It started when the check transmission light came on, and the OD light started flashing one day. I went online and it seems like it's a fairly common issue. We took it to the ford garage who wanted us to spend a bunch of money and couldn't even tell me the code causing the light in the first place. We ended up taking it to another local garage for a transmission flush. While it was there. They found out the code causing the light is a po741. I looked it up, and it appears to be related to the torque converter.
We've been in touch with a local transmission shop that just suggests we pull the transmission and have it rebuilt/replaced (for $4000). We really can't afford that kind of a repair right now.
The vehicle runs, drives, and shifts perfectly fine. I've never noticed any slipping or anything of that nature. The only thing aside from the light that indicates an issue is a whining sound when the rig is idling or driving. This whining sound stops for a second between each shift the transmission does.
So my main question based on the code and info I've listed here. Does it make sense to replace the transmission or would it make more sense (and cheaper) to just have the torque converter replaced?
Thanks,
-RYknow
Thanks,
-RYknow
