followed all instructions and torqued in 2 stages. I now have a leak in the back passenger side. I pressure tested it and I can see the coolant leaking out. No where else. This leak was not there before the change. I cleaned the surface before installing new manifold.
Any suggestions? I was told that I needed to RTV the old OEM gasket alignment holes. I did not do this. But I read that this would cause vacuum issues. Would this also cause coolant leaks if I did not RTV the holes?
