topofffun
- March 19, 2008
- Neenah, Wi
- 01 Explorer 4 door
Well guys i have been waiting for a lift kit to pop up used. I finally found one. It came off of a 2001 ranger its a superlift. It came with all lift brackets plus..... the calipers, rotors, class 1 torsion bars, front drive shaft, front shocks both lower a arm, and one top a arm. So then i called 4wheel parts and ordered the rear leafs u bolts and shocks. I paid that guy 880 and 4wheel parts 450 exactly. Again this is going on a loaded 03 ST I m super hyped some of you know how bad i wanted to lift it. So here are my questions.
1. What are class 1 torsion bars should i just use my stock ones instead?
2. I'm using all of the ranger parts that he gave me anything i should know?
3. With the lift What is the biggest tire i can run on stock 16 or a aftermarket 17 18 20?
4. Should i throw a body lift on while im at it?
5. I have the 3.73 ratio is it going to be a turd with 33"
PLEASE SEND ME PICS OF YOUR TRUCK IF YOU HAVE THIS LIFT WITH TIRES
Thanks in advance.
Thanks in advance.
