03 Trans issue | Ford Explorer Forums - Serious Explorations
03 Trans issue
MOREISSUES
Tunnelton wv
2003 Explorer xlt
I changed the solenoid pack now it won't shift out of 1st gear I'm stumped
Well had it shifting now it goes in reverse for a second then kicks out and get up to speed in drive it goes to neutral until you drop it in 3rd
Queston could the solenoid pack I bought be defective it was remanufactered
Got it off eBay out of California and fluid level is good
If you put the selector in 2, will it manually go into 2nd?
If so, you have a bad solenoid or wire or pin issue on the transmission harness plug.
Mine did this when my solenoid pack broke.
I lost 2nd completely in drive, but manual 2nd worked.
Yes it will go it to 2nd and I already replaced the plug because the bolt broke off in the other solenoid
Sounds like a bad solenoid.
I bought a new one and read somewhere that those solenoids can’t be rebuilt.
Didn't look like they could be but everywhere I look they say refurbished
