What would cause the tranny to have all gears cold but after warming up no gears and burnt fluid
How many miles on it. Drain the fluid Drop the pan install new filter and see what that does for you. Mercon V only. Recommend motorcraft. You may have to do a flush to get all the fluid out. This is the least expensive thing to do.
od sprag less than 100miles. Do you have the invoice for this job. See what fluid was used. Also how did the transmission work before the sprag replacement
It only had reverse and second after it was fixed it had a flare from first to second changed solenoid block no change then replaced wiring harness fixed the flare but now I have this problem
OK I was told today that the 02 Tran I put in the 03 might not be compatible with it is this possible I mean I know one I put in is a w and the one it had was s but that's just a slight ratio change was also told it could be the range senso
