Ragged Jack
- July 5, 2007
- Dawson, IL
- 2003 XLT
I just replaced the factory radio (bone stock, no steering wheel controls, subwoofer or amp) in my 03 XLT with a Sony Double Din unit. It works fine, I used a harness adapter from Crutchfield, and it wired up fine.
My problem is, there is a wire from the Sony unit labled 'Illumination Wire'. The directions say that if there is no illumination wire from the vehicle, to disregard that wire, which I did. The diagram that came with my adapter harness did not mention an illumination wire from the Explorer.
Now the radio lights up obnoxiously bright all the time it is on. During the day that's ok, but it's distracting at night. The lights in my factory radio dimmed with the dash lights, so I have to assume there was a control wire going to it.
On the factory radio, there were 2 plugs going to it. One was a larger plug, which had all the speakers, power, etc. Then there was a smaller square plug with only 2 wires going to it. There was no mention of this plug at all in any of the directions that came with the adapter harness. Could one of these be the illumination wire?
The 12 Volt and Commando sites list the basic color codes for the radio, but don't mention the dimmer.
Has anyone run into this and found the answer? Any help would be appreciated!
Thanks!!
Thanks!!
