04 clicking
dirtydzn784
2004 xlt
I have an 04 xlt thats clicks from under a panel in the trunk can someone please tell me what this is and how to fix it
swetrid
Reading Pa
1999 Eddie Bauer
blend door actuator concern for rear ac
R vent clicking Stock 2002 - 2005 Explorers 5
F 2004 ford explorer Just hear clicking when trying to turn over Stock 2002 - 2005 Explorers 10
D 2002 Explorer Won’t start, clicking after fuel filter change Stock 2002 - 2005 Explorers 10
A clicking noise on 02 explorer when trying to start Stock 2002 - 2005 Explorers 11
K Clicking from fornt driver tire. Stock 2002 - 2005 Explorers 2
H HVAC clicking noise Stock 2002 - 2005 Explorers 1
K Clicking noise Stock 2002 - 2005 Explorers 6
Z Rough Idle, Clicking Noise, and Decreased MPG Stock 2002 - 2005 Explorers 2
0 Clicking Sound When Using the Heat. Stock 2002 - 2005 Explorers 1
M Rapid clicking noise coming from rear climate control Stock 2002 - 2005 Explorers 7
D Audible Clicking - Rear Defrost Stock 2002 - 2005 Explorers 1
K 2005 Explorer XLT 4.0L Outside/Underhood A/C Clicking? Stock 2002 - 2005 Explorers 6
M New brakes make clicking/knocking noise Stock 2002 - 2005 Explorers 2
T Need help to diagnose popping/clicking coming from underneath 2003 Explorer [VIDEO] Stock 2002 - 2005 Explorers 28
S Clicking/Rattle coming from the steering column and dash Stock 2002 - 2005 Explorers 3
B Clicking Noise when HVAC Fan Is On Stock 2002 - 2005 Explorers 4
J High speed and loud clicking sound Stock 2002 - 2005 Explorers 33
T Windshield wipers stopped working and all I hear is a clicking noise Stock 2002 - 2005 Explorers 5
J 02 explorer clicking noise Stock 2002 - 2005 Explorers 3
J clicking sound Stock 2002 - 2005 Explorers 0
F 2004 Explorer clicking noise then died, now won't start Stock 2002 - 2005 Explorers 7
M Clicking noise from front wheels. Stock 2002 - 2005 Explorers 9
T Can a bad transfer case make a loud clicking sound? Stock 2002 - 2005 Explorers 0
G Heater clicking; no heat 2005 Stock 2002 - 2005 Explorers 0
C rear temp control doesnt work and clicking 2004 part# for actuator. Stock 2002 - 2005 Explorers 1
M 2003 clicking on start - no turn over Stock 2002 - 2005 Explorers 8
H clicking sound as tire rotates Stock 2002 - 2005 Explorers 11
P 02 XLS clicking noise from front wheel(s) Stock 2002 - 2005 Explorers 7
B Hearing a clicking when I change between cold and hot Stock 2002 - 2005 Explorers 3
M Clicking Temp Blend Actuator Removal Stock 2002 - 2005 Explorers 9
A '03 won't start, was clicking, stopped Stock 2002 - 2005 Explorers 1
J HVAC system clicking sound no heat!? Stock 2002 - 2005 Explorers 4
W Hear a clicking sound? Read this. Stock 2002 - 2005 Explorers 3
F Rapid clicking when starting the car Stock 2002 - 2005 Explorers 4
M 2002 mercury mountaineer clicking type sound when turning Stock 2002 - 2005 Explorers 3
F clicking noise in the rear headliner from AC Stock 2002 - 2005 Explorers 2
E clicking from rear when turning Stock 2002 - 2005 Explorers 4
G Clicking noise in rear cargo area driver side Stock 2002 - 2005 Explorers 6
S 2002 Explorer won't start as daughter leaves glove box open 24hrs, rhythmic clicking Stock 2002 - 2005 Explorers 3
P Trouble with rear fan clicking/no temp change Stock 2002 - 2005 Explorers 11
K 2002 Ford Explorer Clicking and No Heat Stock 2002 - 2005 Explorers 1
D Clicking from fuse box under the hood & no power Stock 2002 - 2005 Explorers 1
M '05 XLT 2WD Clicking noise front right wheel - advice wanted Stock 2002 - 2005 Explorers 0
I Vibration at 65 and clicking when backing up Stock 2002 - 2005 Explorers 2
B Clicking Sound - Therostat Knob Stock 2002 - 2005 Explorers 1
A Loud clicking 2002 mounty awd Stock 2002 - 2005 Explorers 2
K Clicking in FR tire and now tire is bouncing? Stock 2002 - 2005 Explorers 2
N clicking in motor Stock 2002 - 2005 Explorers 9
B Clicking in Dash Stock 2002 - 2005 Explorers 6
S Wierd clicking on 02 Stock 2002 - 2005 Explorers 0
Similar threads
