joedh12
- March 26, 2013
- Lawton, OK
- 2004 Ford Explorer
I recently change the EGR module in my 04 Explorer because the SES light came on and the trouble code said the EGR was ineffective (can't remember code number). It wasn't running bad before the swap but after I replaced it with a new one it started idling rough and would stall out at stop lights. I took it to autozone where they told me it threw a few trouble codes. p0190 (Fuel Rail Pressure Sensor fail), one for EGR inefficient flow, one for DPFE fail, and I think they said one or two for O2 sensors but they didn't give me the print out for that one. Autozone said they believe the p0190 code was causing all other codes to come up. My question is what the heck is wrong with it. It was fine before I replaced the EGR valve, after wards it ran horrible (rough idle, stalling at lights and when shifting from R to D) and the next day it wouldn't even start, and hasn't started since.
I've tried putting the old valve back on, unplugging the EGR valve, and unplugging the MAF sensor. When I try to start it, it will turn over but it's not firing, every once in a while it'll act like it's going to but it doesn't. I checked the plug wires to make sure they're sparking and I can hear the fuel pump turn on when I turn the key.
