PBB
- February 21, 2015
- Atlanta,GA
- 2004 Ford Explorer EB
First, I wanted to thank the owners, moderators and all the contributors to this forum. IMO, This is definitely the best car forum on the internet! We have had an Explorer or Three in the driveway since 1995 and anytime we have had an issue this forum is the first place my son and I go to when researching a issue whether or not we DIY or let the mechanic do it! Enough sucking up.......
The Window Uplift Motor on the front drivers' side window is dead. Removed the panel and the switch panel. Took the test light and confirmed power to the switch. Tested the switch by depressing the up/down and the corresponding wire at the motor.
I was looking at a couple of the auto parts websites (Definately,Not Autozone!) and I noticed you can purchase a window uplift motor or Window regulator. Can you replace the motor leaving the rest of the regulator in place or do you have to pull the entre assembly and remove and replace it on the bench? If I have to pull the assembly, I will just replace the entire regulator. If I can just swap the motor I will go in that direction.
Any thoughts ? Thanks in advance for all the help!
Patrick
Atlanta,GA
Patrick
Atlanta,GA
