04 Explorer no heat
muddawg019
2004 Ford Explorer
My 2004 explorer has no heat. the doors seem to work fin so i dont think its the acuator. checked all the fuses and are all good. just blows cold air and will no blow hot air. Any more ideas?
arco777
1994 Explorer 2dr 4x4
Check the heater core. Both hoses to the core should be the temperature of the engine coolant. If one is much colder than the other there may be a blockage in the core. Also, is the engine heating up normally? If a stuck open thermostat and cold weather keep the engine from warming up, the coolant won't be warm enough to heat up the heater core.
