jackofsome
- December 20, 2015
- 04 X-limited
Found a bunch of info on this forum (including a wiring diagram/pinout). The problem is that if you have a RSE, the head unit in my Explorer sends Canbus Protocol signals to the RSE that you need to keep it on. When I simply jumped a 12v across to the DVD harness, it would power on, then kick off.
No manufacturer that I could find makes a plug/play harness to accomodate keeping the RSE for an 04. I even ordered a PAC FORDAH for an 06, and while the plugs fit, the pinout was different and even with a correct pinout, the canbus signals didn't cut it. I didn't really want to have to stash a bigass double din head unit somewhere, and running wires would have been a pain. So this is what I ended up with.
What I ended up doing was disassembling my stock audiophile unit, and removing just the motherboard, and mounting that behind the glove box, and running a 12v(always on), ground, and a 12v (ignition) jumper across to the stock motherboard, then plugged in the OEM dvd harness to it, and spliced the audio outputs from the DVD player to a pair of RCA cables to my new head unit. Works like a charm.
Hope this helps somebody in the future.
