jtrasap
- July 9, 2010
- Altamont, IL
- 04 mounty
I have a few gears in my head turning and a few questions to ask. Last week, I purchased an 04 Mountaineer as is with a front end/TC binding issue. It has been driven for quite some time with mis-matched tires, and I am suspecting that I will need to replace the viscous coupling, but I'm a bit low on funds after purchasing the truck so I'm going to remove the front drive shaft until I can afford to fix the TC and buy a new set of tires.
The truck is full time AWD and does not have the "control track" option. I would really love to have the option of 2wd and 4-lo if possible. I noticed that the 3rd gen Explorers have the ability to switch between 4wd auto, 4hi, and 4 lo, and, with the "brown wire mod" can be made to disable 4wd all together. Has anyone done a swap or mod to a Mounty to give it these options?
Does anyone know the differences in the TC's and would it just take a TC swap and add the switches? What complications I might run into? Any input at all would be really appreciated.
Thanks in advance
Jason
Thanks in advance
Jason
