05 explorer 5r55w 2-3 shift delay
alexknappenberger
2005 explorer
Hi I scored a 05 explorer for dirt cheap at an auction the other day pretty solid overall I figured it would make a good junk hauler or winter beater for myself. it has 135,000 miles, no telling if those are city or highway miles though ha. first time driving it I realized why it prolly ended up at the repo auction the tranny is acting up a bit. I have some experience with shifting problems and replacing solenoids/valvebodies and this is the least extreme case I've encountered it doesn't seem that bad so hopefully it's nothing major. The two symptoms I've noticed is, a very slight delay when putting it in drive, not major but enough to make someone that knows cars notice. And The 2-3 shift is very slow, I decided to just let off the throttle when it goes to 3rd to avoid further damage, it shifts into 3rd ok when you let off the throttle but there's a huge flare if you stay on the throttle. rest of the shifts are fine, overdrive works. I did get a blinking overdrive light once I have yet to pull the codes. Haven't even looked at the fluid yet neither I'll report back with that tomorrow just hoping someone can give me some general advice for now. The last car with tranny problems I had was also a Ford, and it had no 3rd gear at all which I ambitiously tried to replace the solenoids only to find major clutch material debris in the pan and obviously the solenoids didn't help, even though two were in fact dead, it being driven with those dead solenoids apparently damaged it further. If it's solenoid related in this explorer hopefully I can sort it out before that becomes the case
alexknappenberger
2005 explorer
C Harsh 3-4 shift in 5R55W, 2004 Explorer... Transmissions & Transfer Cases 0
C 2002 explorer p0741 code. 5r55w transmission problems. OD light flashing. Transmissions & Transfer Cases 2
T 2002 Explorer with a broken servo piston in a 5R55W transmission. Transmissions & Transfer Cases 4
L 5R55W transmission on 03 explorer leaking Transmissions & Transfer Cases 3
J 02 eb explorer 4.6l 4x2 trans error 5r55w Transmissions & Transfer Cases 0
C 2002 Ford Explorer 5R55W Transmission Question? Transmissions & Transfer Cases 3
U 5R55W -2002 Ford Explorer - Servo Replacement Saga. Transmissions & Transfer Cases 29
T 2004 Explorer 5r55w no passing gear? Transmissions & Transfer Cases 1
E 2002 Explorer. My 5R55W lost all gears after replacing the solenoid block & fluid. Transmissions & Transfer Cases 13
H 05 Explorer 5r55w band broken Transmissions & Transfer Cases 1
A 04 Explorer 5R55W Solenoid Pack Question Transmissions & Transfer Cases 3
T 2002 Explorer Transmission 5R55S Problems can I replace with a 5R55W??? Transmissions & Transfer Cases 1
M 02 Explorer 5r55w to Man trans? Transmissions & Transfer Cases 0
F 03 Explorer xlt 5R55W trans issue Transmissions & Transfer Cases 0
R 2004 V8 4x4 Explorer - 5r55W Tranny - Kicks Hard Transmissions & Transfer Cases 9
R Help! Replaced transmission, problems (5r55W, 2002 Explorer). Transmissions & Transfer Cases 5
T 5R55W 02 Explorer 4x4. I've had it for a week, and it now has a flashing O/D light? Transmissions & Transfer Cases 14
AIRBLUE Tranny Flush 2002 Explorer 5R55W "sealed" No Dipstick Transmissions & Transfer Cases 5
S 04 Ford Explorer Transmission and transfer case issues Transmissions & Transfer Cases 0
S 2002 Ford Explorer Transmissions & Transfer Cases 2
C 2004 Ford Explorer transmission. Options? Transmissions & Transfer Cases 3
C 2000 ford explorer sport clutch hydraulic line problem Transmissions & Transfer Cases 2
J 2005 Explorer 4.0 No drive, No reverse and No line pressure Transmissions & Transfer Cases 6
T How to tell if the converter is locking up on a 1993 Explorer Transmissions & Transfer Cases 15
Z Transfer case went out on my 97 4.0 explorer :/ looking to replace asap Transmissions & Transfer Cases 16
C 97 Ford Explorer XLT 2WD 5.0/Clutch Plates Transmissions & Transfer Cases 2
C 97 Explorer XLT 2WD 5.0/ Clutch Plates Transmissions & Transfer Cases 4
T HELP 06 Explorer Transmission Issues Transmissions & Transfer Cases 1
C 03 Explorer is light flashing and popping into 4th Transmissions & Transfer Cases 1
M 94 Explorer not shifting right Transmissions & Transfer Cases 0
A 08 Ford explorer limited transmission question Transmissions & Transfer Cases 0
1 1998 Ford Explorer Manual Trans: Bleeding Master & Slave Transmissions & Transfer Cases 2
J 94 Explorer xlt 4wd Transmissions & Transfer Cases 1
R Will a transmission from a 4.6 ford explorer work in a 4.0 explorer? Transmissions & Transfer Cases 4
M 2002 Ford Explorer Transfer case housing gasket. Transmissions & Transfer Cases 9
S 98 Explorer 5r55e to m5r1 electronics Transmissions & Transfer Cases 7
J 1998 5.0L V8 Explorer BW 4404 TC Transmissions & Transfer Cases 2
A 98 ranger with 02 explorer sohc ecu Transmissions & Transfer Cases 0
M 2016 Explorer PTU Transmissions & Transfer Cases 1
W 2006 Explorer Transmission Removal - Top 2 bolts Transmissions & Transfer Cases 5
1 2002 Explorer 4x4 not working Transmissions & Transfer Cases 2
W 02 Explorer Transmission Leak Transmissions & Transfer Cases 11
imp Thread about non-Explorer Axle? Transmissions & Transfer Cases 2
J 2005 explorer axle 45 need traction...swap diff to torsen style? Transmissions & Transfer Cases 6
B 2000 Explorer trans slips in reverse Transmissions & Transfer Cases 15
F 2008 Explorer 4.0L Torque Converter Problem Transmissions & Transfer Cases 4
O 2002 ford explorer v6 xlt drivetrain thumping Transmissions & Transfer Cases 0
P 2007 explorer trans pan with dipstick Transmissions & Transfer Cases 2
T 1995 Explorer 4wd speedometer not working OD light flashing Transmissions & Transfer Cases 2
C 03 Explorer 4.6 Torque Converter, Difference? Transmissions & Transfer Cases 0
Similar threads
