Andy32225
- March 17, 2013
- Jacksonville, Florida
- 2005 XLT Advance Trac RSC
Hello All, New to this Forum so please bear with me. As stated I own a 05 EX XLT V6 RSC/Traction Control. Have a few issues. I did feel the need to swam the forum with many threads so I will post them all here. Thanks for any advice.
1. While driving at any speed,, the slightest touch of the accelerator I hear a distinct whineing noise. It don't matter is I am going up hill or down hille or on level ground. It does it with only myself or a packed truck. Makes no difference of weight in truck. It is quite annoying. I have already replaced the rear wheel bearings and diff was rebuilt. Still the noise remains. It only happens the second I touch the accelerator, meaning the slightest touch of it, the noise returns, I lift off and it goes away.
2. I have NO heat. With the truck running, when I turn the temp dial to heat or actually about the 9-10 oclock position, I hear a clicking noise and a relay or something ticking, all coming from behind the dashboard. A/C works fine but not much air flows from the vents. Seems like something is blocked or not switching. Blend door actuator???
3. Every once in a while I lose my ABS/Trac Control. The light comes on and the onboard diagnostics system beeps telling me it turned itself off. It doesn't do it all the time. Driving is not effected at all, I just spin my wheels in rain more A bad sensor and if so How do I figure out which one? I have checked connections to the rear ABS sensors, seem to be tight.
4. Drivers side door, again while driving I can hear air coming in but can figure out where it is coming from. When the door is closed it does seem that it dont shut all the way, as it sticks out about 3-4mm from the body seam.
5. Do I need any special equipment to replace the front shocks? I am hearing a noise when when I go over a speed bump a bit faster then I should be going.
6. On the rear liftgate, the plastis just the rear glass has somehow cracked in half just about under the rear whiper arm. Can this be replaced? It is astetically annoying
7. A Sealed Transmission?? There is no dipstick visable. How do I flush the tranny and replace fluid or should I just leave it be? That is the only fluid that has yet to be changed since I bought it. I am wondering If I have to evac the tranny thru a cooling line or something?
This again is a 2005 Ford Explorer XLT RSC Advance Trac with about 110k miles. I bought it used when it had about 70k miles. Runs great apart from the above mentioned bugs. Thanks for any answers/help. When replying to a question, please just say like question 4 or something like that. Again Thanks so Much.
