05 Sport Trac front driver side door doesn’t lock or unlock | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Huntsville
05 Sport Trac
So the driver side door had gradually been acting worse for a couple years now. When I’d try to lock it it would go half way down but not actually lock and sometimes it wouldn’t unlock. Now it just outright refuses to work either way. Seemed like it got worse when the weather started heating up? I don’t know for sure. I’d just like to know what parts I should consider replacing. Unless someone on here has a easier fix.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
eevox
Powdersville Georgia
2004 Ford Sport Trac XLT
It's most likely the door switch. They do go out. However, sometimes the wires leading from the door switch get broken. Some people report that this happens with one or more of the wires leading from the truck's body to the door, through the black plastic boot between the door and the body of the door frame. This is not an uncommon problem.
Huntsville
05 Sport Trac
Okay, but I just learned something new. When I put my key and try to roll it over manually it’s slips and doesn’t work. This isn’t a constant thing, but it does happen. Could it be the lock? Could it still be the switch? Could it be both?
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
You're referring to manual locking and unlocking with the key? If so, first thing I would do is spray Lock-Ease or similar lubricant in the key hole. Also lubricate the door latch while you're there. Other possibilities are a slipping or broken plastic linkage connected to the key cylinder or a linkage rod.
Only way to find out is remove the door panel and inspect.
Huntsville
05 Sport Trac
I replaced the actuator and now it works like a charm. Figured I’d come back with the solution here in case anyone else has this problem.
