05 st 4x4 5r55e transmission help
Johnnyb83
Location
Ohio
Ohio
2005 sport trac 4x4 xlt
New member but recently dedicated fan of the forum..
Ok problem appeared on freeway. Wont lie, i floored it to pass someone who wouldnt let me get over.. when i put the pedal down felt as if the truck went into neutral. I quickly found that warm or cold. I can start in either 1,2 on the tree. Then i can shift into drive as long as overdrive was turned off. Once up to 45 i can turn od back on. My reverse works sometimes. I have to shift from park to 2 to reverse at which point it sometimes engages. Drive if babied and im talking my grandmother can scoot along faster in her walker and beat this thing 100feet before it engages enough to go if started in drive.. so the million dollar question.. whats wrong with that tranny? Sounds like fords private joke of a game show lol
Ive noticed reverse becoming stronger in pasy few days.. I do my best not to drive it but sometimes im forced to due to lack of vehicles per adults because mine is down.. I will add i dont have the best of luck owning cars/trucks/suvs. I do all my own mechanical work and follow specs to a T.
Vehicle specs and repairs made below
2005 ford explorer sporttrac xlt
4.0l
5r55e 4x4 trans
177k miles
Recently purchased on 10-2-19
Engine oil / filter change on purchase date
Replaced trans filter and trans oil pan gasket along with fluid recommended merc v after trans problem
Repaired massive trans fluid leak in filler tube.. the tans fluid dip stick tube had a five inch long hole in it where the dipstick would rub the inside of the tube at a bend.
I Need jack assembly for 03 Ford Explorer Sport Trac XLT 4x4 2001-2005 Explorer Sport Trac 2
B 02 explorer 4x4 light low 2001-2005 Explorer Sport Trac 0
D New member..My 01 Sport 4x4 hunting rig 2001-2005 Explorer Sport Trac 1
I 03 Ford Sport Trac XLT 4 Door 4.0 4x4 power mirrors not working 2001-2005 Explorer Sport Trac 1
0 4x4 starter replacement 2001-2005 Explorer Sport Trac 0
P 4x4 low light. I'm in neutral and brake pressed 2001-2005 Explorer Sport Trac 4
1 Manual Transmission in 4x4 Sport Trac 2001-2005 Explorer Sport Trac 21
D 2001 explorer sport trac 4x4 system 2001-2005 Explorer Sport Trac 3
A is it possible to install struts insted of shocks in a 2005 4x4 sport trac 2001-2005 Explorer Sport Trac 4
D '02 Ford Explorer going into 4x4 high on it's own... 2001-2005 Explorer Sport Trac 8
W Use 2002 EBauer body parts for 2001 Sport Trac 4x4 2001-2005 Explorer Sport Trac 2
D Rear Bearings for 2003 Sport Trac 4x4 2001-2005 Explorer Sport Trac 8
R 2001 4x4 misfire 2001-2005 Explorer Sport Trac 0
T Shims for 8.8" Trac Lok Differential on 2002 Sport Trac 4X4 2001-2005 Explorer Sport Trac 0
J Shifting 4x4 transfer case with pliers 2001-2005 Explorer Sport Trac 1
C Cannot engage 4x4 unless driving over 30 mph 2001-2005 Explorer Sport Trac 9
C Winter Time, 4x4 issue 2001-2005 Explorer Sport Trac 1
R Pulls left in 4x4 HELP 2001-2005 Explorer Sport Trac 0
B Looking for rear end w drums for 02 ST 4x4 4.10 gears 2001-2005 Explorer Sport Trac 2
B Wheel bearing change, Can I use 4x4 wheel hub on 2wd? 2001-2005 Explorer Sport Trac 3
S V8 and 4x4 Transmission Swap 2001-2005 Explorer Sport Trac 1
B 2003 explorer 4x4, Auto lights & locks 2001-2005 Explorer Sport Trac 0
C 4x4 indicator issues 2001-2005 Explorer Sport Trac 0
Z Tie Rod End 04 4x4 2001-2005 Explorer Sport Trac 2
S 2004 sport trac 4x4 control module 2001-2005 Explorer Sport Trac 2
B 02 ST 4x4 HELP NEEDED PLEASE !!!!!!!! 2001-2005 Explorer Sport Trac 13
Z 04 Sport Trac makes noise when turning and 4x4 engaged 2001-2005 Explorer Sport Trac 9
R 2004 Explorer xlt - 4.6l - 4x4 (dependability advice) 2001-2005 Explorer Sport Trac 3
F a thump noise every 20 to 30 sec. on 4x4 2001-2005 Explorer Sport Trac 4
K Whining 05 Sport Trac 4x4 2001-2005 Explorer Sport Trac 3
H 2001 ford explorer sports trac 4x4 issue 2001-2005 Explorer Sport Trac 19
J Sport Trac 4x4 Lift Options Discussion 2001-2005 Explorer Sport Trac 0
1 How new of an auto transmission will work in an 02 V6 4x4? 2001-2005 Explorer Sport Trac 0
S 4x4 swap questions 2001-2005 Explorer Sport Trac 2
B 4x4 stuck in 4lo 2001-2005 Explorer Sport Trac 3
M Trying To Narrow Down 4X4 Problem 2001-2005 Explorer Sport Trac 5
M Groan/grumbling noise, only in 4x4 2001-2005 Explorer Sport Trac 0
P Help with Sport Trac 4X4 differences 2001-2005 Explorer Sport Trac 6
K 2001 Sport Trac Hello and 4x4 transfer problem 2001-2005 Explorer Sport Trac 3
C 4x2 to 4x4 conversion help!!! 2001-2005 Explorer Sport Trac 5
M 2001 Sport Trac 4x4 problems 2001-2005 Explorer Sport Trac 4
M 4x4 How and when to use 2001-2005 Explorer Sport Trac 7
S 17" wheel and tire size on 01 4x4 2001-2005 Explorer Sport Trac 7
B 2002 Sport Trac 4x4 Axle Nut Size - Front 2001-2005 Explorer Sport Trac 3
G 4x4 will not disengage - 2004 explorer sport trac 2001-2005 Explorer Sport Trac 4
J 05 sport trac 4x4 kicking out 2001-2005 Explorer Sport Trac 1
A Lost 4x4 in my 2001 4.0 6 cyl. Sport Trac 2001-2005 Explorer Sport Trac 5
G Clutch problems/Will not shift into Gear on a 2003 ST 4x4 2001-2005 Explorer Sport Trac 3
V 4x4 nothing 2001-2005 Explorer Sport Trac 3
P 2001 explored sport trac 4X4 2001-2005 Explorer Sport Trac 3
Similar threads
