g5IGUWg5s
- April 22, 2016
- 2006 Ford Explorer XLT
On Monday, after 60 miles of highway driving, I began to notice that my brakes were engaging on their own without pushing on the brake pedal. It was subtle at first, but after 5 more miles there was a lot of noise.
My best guess is that the squealing, popping and shuddering sounds were coming from the Driver Rear and Passenger Front.
Yesterday, I purchased and installed new rotors, brake pads, guide pins, caliper bolts, pad clips and rubber bushings (thinking that the slide pins were causing issues). Parts cost was $406.77.
Today, I drove 30 miles without issue and then it started happening again. I could tell that both front brakes were being engaged briefly, but it was very apparent that the Driver Rear was sticking and making the most noise.
I parked at my destination and did a visual inspection and didn't see anything out of the ordinary. But, all of my rotors were warm/hot to touch.
Should I replace front and/or rear calipers? Master cylinder? Brake lines? Brake booster? I'm not where to go from here. Thanks in advance for any insight!
