06 Explorer Audio | Ford Explorer Forums - Serious Explorations
06 Explorer Audio
dothedeww
West Friendship, MD
2006 Explorer XLT
Alright..I posted a little while ago on this but I cant find the post.
I have an 06 XLT....1CD player blah blah blah. IS there a factory sub? Is there a factory amp?
IF I want to get a new sub...would I need a new amp? WOuld I need to rewire...or is it already wired and just kind of plug and play?
Thanks!
if there is a sub, it is in the right side of the cargo area.
My 6cd w/sub just stopped reading discs (since we recently just hit 100 for several days) but will read from time to time. The radio is fine, ejects/loads discs fine... very disappointed. Thinking there must be a reset/default settings/reboot sorta thing... or if the batter disconnect trick might work... probably a bigger issue thou..
ya. Mine stops reading discs from time to time but will just work perfectly if I just turn off/on engine.
And is the sub visible? Or do I need to pull off paneling...if so..how?
Vented panel, should be obvious, thanks
Ya. The panel is vented..towards the lifegate. Is that the sub I guess? OR do I need to look through it?
And do I need to rewire?
Shouldn‘t you hear if there is a subwoofer or not?
That's what I would think. I have a 2006 Ford Explorer XLT with single cd player, no steering controls. I am having the same issue. I see what appears to be a speaker grill but it doesn't seem like it is behaving like a sub-woofer. I have a 2006. Can someone take a picture of what I am looking for? I sure would appreciate it. Thanks!
