06 Explorer with a brake fluid low light on. | Ford Explorer - Ford Ranger Forums - Serious Explorations
keithwitt
My 2006 explorer has the brake fluid low light on, which kicks on the brake light. However, the reservoir is full of brake fluid. Is it possible that the float in the reservoir has stuck?.
bronco466
monmouth ill
2000 mountaineer
That is very possible that or the senser went bad .I have worked on this problem in the past and fix it with a brake flush if the plunger is stuck.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Riken
does the light actually say 'brake fluid low' or is it the 'brake' light. check that the parking brake pedal is all the way to the top.
