Zieg95x
- December 28, 2012
- Gettysburg,PA
- 1995 Ford Explorer
My explorer has 91k on it and was wondering if the spark plugs should be changed early and when the trans fluid should be changed. i only had luck with Motorcraft plugs on my 95 is the SOHC motor better with motorcraft plugs also. Also should wires be done with the plugs. Does a ford dealer flush the trans and if they do what does it have any bad effects on life of the trans.
