07 4.0 4x4 trany replaced now tons of issues
SynGen79
Blackwell, Oklahoma
07 sporty xlt 4.0 4x4
Tranny went out at 120k. Found one online and had it shipped to tranny shop. Had new flywheel put in at the same time. Got it out of the shop and drove to work about 5 miles. Ran great. After work, pulling out of the lot it goes into limp mode. Take it back thi the shop. Calls next day. Pick it up. Drive to work and home just fine. Next day 5 miles from home, into limp mode again. All sorts of dummy lights. Tranny guy says it's throwing codes, so I take it to the Ford dealership. They say bad o2 sensors and need new cats. So I get new upstreams and gut the cat's and put in non foulers. Still same codes. It does good for about 3-5 miles then goes retarded. Changed the plugs wires and coil pack to stop the random misfire codes. No luck. Help me. Ive finally got time to hunt gremlins on this truck. Thanks in advance. D
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
what are your codes? <----------------------------------- most important
What year transmission was installed?
Do you still have your old 07 transmission for parts if needed?
  • Like
Reactions: imp
SynGen79
Blackwell, Oklahoma
Tranny was installed a year ago. Shop kept the old one.
Codes are random misfire, o2 bank 2, and range selector. I don't have an obn scan tool. It won't start at this point without a new flywheel. Will it show codes even if it isn't running? Thanks for your time
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
random misfire, okay can be caused by......many things
02 sensor bank 2 IS DOING WHAT?
RANGE SELECTOR - OH BOY! This is why I asked if they took the core.
yes it will give you codes even not running
We need the actual codes, not the definition so we can give you the definition
The range selector code - you can check to ensure the wiring down at the side of the transmission is secure, clean and in good shape
What happened to the flywheel??
  • Like
Reactions: imp
SynGen79
Blackwell, Oklahoma
The shop broke one of the ears off the starter and didn't bother to mention it. The wife cranked on it one day trying to go somewhere and it just spun, so I replaced it and when it throws out, it spins freely. Im thinking the teeth on the flywheel got rounded off?
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
yikes
Need to remove starter and have a look see
This shop SUCKS
What year did the transmission you found online come from?
SynGen79
Blackwell, Oklahoma
yikes
This shop SUCKS
I'd read on some forums about how the trannys were vehicle and year specific. So I made sure that it was from on 07. I'm thinking they put one in out of a regular explorer.
M Trac 08 4x4 2007 - 2010 Explorer Sport Trac 3
0 How to convert your 'AWD' Adrenalin to true 4x4 2007 - 2010 Explorer Sport Trac 11
J ST: Limited Slip Differential Install Into 4X4? 2007 - 2010 Explorer Sport Trac 1
T 2007 sport Trac v8 4x4 2007 - 2010 Explorer Sport Trac 13
T 2007 Sport Trac limited 4x4 - ABS fuse location 2007 - 2010 Explorer Sport Trac 3
Dave Head new to me 2007 V8 4X4 Limited 2007 - 2010 Explorer Sport Trac 9
L Sport Trac 2010 4x2 to 4x4 conversion. 2007 - 2010 Explorer Sport Trac 0
A 2007 Sport Trac Limited 4x4 - Upgraded Brakes? 2007 - 2010 Explorer Sport Trac 3
T '07 v8 4x4 Transmission Leak - Wiring harness? 2007 - 2010 Explorer Sport Trac 6
B 4x4 auto light 2007 - 2010 Explorer Sport Trac 3
S HELP need frame schematic for 07 4x4 4.6L 2007 - 2010 Explorer Sport Trac 0
C Auto 4x4 - 2010 STA 2007 - 2010 Explorer Sport Trac 10
B Big Tires 07 4x4 2007 - 2010 Explorer Sport Trac 5
W 4x4 tow kit 2007 - 2010 Explorer Sport Trac 4
J 07 4.6 4x4 major problems~!!!! 2007 - 2010 Explorer Sport Trac 10
F 08 sport trac limited 4x4 inop 2007 - 2010 Explorer Sport Trac 1
S 4X4 Control Module 8L2Z7E453C 2007 - 2010 Explorer Sport Trac 0
0 4x4 Auto 2007 - 2010 Explorer Sport Trac 5
0 max speed question in hi/lo 4x4 2007 - 2010 Explorer Sport Trac 6
H No 4X4 low (new ST owner) 2007 - 2010 Explorer Sport Trac 5
Lil98Sport4X4 My '07 Sport Trac Limited V8 4x4 2007 - 2010 Explorer Sport Trac 87
T 4x4 vs. AWD ? 2007 - 2010 Explorer Sport Trac 6
P Tow Questions 2008 Sport Trac V8 4x4 2007 - 2010 Explorer Sport Trac 3
C Why is AWD more expensive then 4x4 on new sport trac? 2007 - 2010 Explorer Sport Trac 50
R 4x4 auto button ??? 2007 - 2010 Explorer Sport Trac 2
S Venting about my 2007 Sport Trac Ltd. 4x4 V8 2007 - 2010 Explorer Sport Trac 27
B ABS codes C2777 and U1901 after ABS Module replaced by dealer 2007 - 2010 Explorer Sport Trac 4
A Explorer shaking at 70mph after front wheel hubs replaced 2007 - 2010 Explorer Sport Trac 4
F shifting in to Gear after transmission replaced 2007 - 2010 Explorer Sport Trac 1
E Fuel Filter Replaced 2007 - 2010 Explorer Sport Trac 0
