    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
07 Sport trac bed storage components
LorenzoGarbanzo
Nashville, TN
2007 Sport Trac XLT
I'm trying to find a couple of parts to make my in-bed storage boxes usable again. (Refer to diagram)
1-2: The hinge has broken on both of my side storage boxes, I can't find this part by number anywhere. I'm unsure if I can even get the part, salvage it without breaking it, or modify with a different type of hinge. Has anyone run into this?
9: The strut has gone bad on my front compartment, I found the part online for about $200 think that's a bit much. Is there a cheaper option out there?
zadigadabop
Orlando, Florida
2007 Sport Trac Limited
For 1-2 (or do you mean 3 since it's highlighted?): You might be able to make the hinge (#3?) with some good quality plastic that can take a lot of bending. This hinge is really hard to remove. I got one at a salvage yard and since there's a tab I couldn't get to, I ended up taking the fender off.
Is #1 plastic/SMC (sheet molding compound) and part of the bed? It should be good right?
#2 is the door seal which you could make it some weatherstripping.
For 9: There's a non-OEM strut an Amazon (2 for $35, just search for 7A24-99286D18-AB). Otherwise there should be a manufactures P/N on it. Or maybe use a similar gas strut (this one is 7.8" extended).
Hope this helps some,
Steve
LorenzoGarbanzo
Nashville, TN
2007 Sport Trac XLT
Steve
I did mean 1 & 3. Typo. I did find some plastic hinge material that looks kind of similar to the stock hinge that can be cut to fit. I'm also considering some sort of metal hinge to put in place. Thanks for all the info.
