chriswh86
- October 21, 2012
- 2009 Sport Trac Adrenalin
Hi all,
Just wondering where the drain tubes are located at the sunroof in an 09 sport trac? Also, where do the sunroof drain(s) end up draining out from?
I can see water dripping in when it rans in the left rear corner of the sunroof seal but cant tell where it drains out to.
Also, I have been having water dripping out from the panel above the rear view mirror. The panel that controls the sunroof/rear window and map lights. Usually happens when the nose is lower than the rear if I remember correctly. Seems like a weird place to leak from but its annoying, could this be plugged sunroof drain tubes?
It happened pretty early in the life of my explorer and I had originally thought it was the 3rd brake light leaking but now I am not sure. I know the sunroof seal is leaking so..
