100k mile maintinence/ long driving | Ford Explorer Forums - Serious Explorations
leetz
2wd All-Star
Miami, Florida (School) Va.Beach, VA (Home) Beaufort, N.C. (Home)
98 Explorer Sport
Alright guys I am about to be driving to Miami Florida. I'm going to school there for air traffic control for 2 years. My apartment where I'm going to be living does not allow me to work on the truck in the parking lot, so I want to get stuff done before I leave. Basically doing some preventative maintinence while I still have a driveway. Searching through posts and other things, I think I have found alot of the stuff I should do, but please fill in if you think I need to do anything else.
This stuff has been done in the past week. Thanks to Chris(boominXplorer) for the help.
-Replaced spark plugs and wires.... Motorcraft wires Platinum Plugs
-Oil changed, switched to Valvoline Synthetic blend with motorcraft oil filter.
-1 can of Seafoam through the IAC.
-Used 2 bottles of STP fuel injector cleaner.
- Flush'ed and recharged A/C system.
-Cleaned KKM air filter and re-oil'ed
-Cleaned MAF sensor
-Replaced lighting with Clear Corners and Silverstars all around.
On a side note: I noticed a def. difference in performance of my motor after doing all this stuff. It idles better and even seems more responsive. It would be a good idea for anyone to do this.
Stuff done in the past.
95k Miles
-replaced brakes around whole ex with ceramic pads and drilled and slotted rotors.
right around 88-90k miles
-Transmission fluid was flushed and changed
-New Starter put in
-Alternator replaced
-Serpentine Belt replaced
-Exhaust system replaced with dual exhaust setup
-KKM Air Filter Installed
-3 inch body 2 inch torsion shackles and 33 inch tires added
-4.56 Gears Installed
-Alignment
-Shift Kit Installed
That is all that has really been done since I have had the truck I am the second owner. Is there anything major I'm missing that should be done at 100k miles?
Thanks
How about a Coolant Flush, and replacement of all cooling system hoses? Differential fluids replaced, spare tire checked, brake fluid flushed/replaced are a few suggestions. You might want to change the idler pulley now before the bearing goes out of it when your down in Florida...
No spare tire.
but ya I think I should do the brake fluid and the diff.
Is the idler pulley similar to the tensioner pulley? I just had to replace that a few months ago. If it's not too difficult I'll prob do that too.
I'm not sure how to do the all the coolant stuff , but I will search on here and see.
Thanks man
I would definitely replace the dif fluid.
The idler pulley is similar to the tensioner pulley except is easier to change and cheaper; cheap insurance.
Good luck .....
This is the ideal time to check your ball joints, upper AND lower on both sides.
