I am just starting to shop for my new tire/rim combo. I've got 1.25" torsion keys + tt for the front, doing a re-arch/aal on the rear and a 3" bl. I want to run 33"tires. I really like the look of 305/70r16 but the stock rim is too skinny. the only rim I've found in the design I like that may work is 15x8" wide, 3.75" bs, -19mm offset. Which means I would look at 33x12.5r15 tires. I'm fine with stepping down an inch on rim size if theres no problems with hitting/rubbing the LCA or calipers etc... But my main question is all the tires I've looked at say 8.5-11" rim is recommended. Can I safely get away with a 8" wide rim? useing a 33x12.5r15 tire? Also will the BS/offset stated above be a good fit? Oh my Ex is a 2002 2dr Sport 4.0l 4x4.
