15 x 7 stock wheel offset | Ford Explorer Forums - Serious Explorations
Hi Fellas.
I have a 97 XLT with a stock 15 x 7 alluminum tear drop wheel. Does anyone know the exact offset or back space of these babies?
Since I already know how much more I could fit inside the wheel well using these wheel, I could easily upgrade my wheel/tire.
I currently have the aforemention wheel with 265 70 15. I plan to up grade to 17 x 9 with 285 60 17. Is this doable?
Thanks all.:p
Probably doable, but it would be very ugly.
Stock BS is 4-4.5" depending on the rim. You may have trouble fitting a wide tire like that without rubbing.
The 15" rim is from a 97. If the backspace is 4-4.5 then that means the offset isn't zero?
I'm confuse...
Honestly I don't know the offset (think it's zero). What I was saying is that various X/Ranger rims range from 4 to 4.5" BS. Yours are probably 4.5.
Emon, I just measured my backspacing. It is 4 1/8", measured from the flange which the tire bead rests on. Some people measure from the extreme outside edge of the wheel, which will add on another 1/2".
This gives an offset of +5/8". I think the Ford specs are actually +20mm, which is pretty close to 5/8".
All of the above measurements are on a 7" wide rim.
