18" vs 20" wheels?
paulfrank285
Union, NJ
2011 EXP XLT
hey guys...the more I look at the new Explorer's pictures, the more I want the bigger wheels and tires...I ordered a XLT with standard 18". I want the 20" just because they look good, no other reason (for now). I compared the size with other rivals, of similar SUV (seats 7), most of them offer 17-18" as standard, 20" for top-of-the-line, so I feel better.
What do you think? Besides being looking good (also more expensive to replace), does it ride better with 20" than 18"? better handling?
They have not built mine yet (build date 3/30), is it possible or is it too late to tell my dealer to add the 20" rims if i decided to get them?
Thanks, need your 2 cents!
JustB_Rad
Milwaukee WI
2011 Explorer XLT
Bigger wheels and smaller tires will never ride better.....The sidewall of the tires is what gives when the suspension doesn't.
Wightmn
Olathe
04 XLT, 11 XLT on order
Bigger wheels don't perform better either. They are heavier resulting in an increase in unsprung weight. Tires cost more and they are harder on brakes. But the do look good.
Carguy3J
North East New Jersey
'99 4dr. XLT SOHC A4WD
A.) 20" or larger wheels look "ghetto"
B.) I used to live in Union. Trust me, you'll be happier with the 18"s. With all the bumps, potholes, choppy pavement,etc..., the 20"s will rattle your teeth, and put more wear/stress on the suspension/chassis
rescue_31
Chicago
2011 XLT
@ Wightmn, not necesairly. A lot of manufactures are going from the smaller rims to larger ones for a weight reduction, due to heat treatment, and design process of different grades of aluminum, rubber actually weighs more, and less rubber is more eco friendly. There is no logical reason why a larger rim, will have a greater effect on brake life.
Im trying to find exact info on the ford wheels. But looking at the 20's compared to the 18's, there is a lot less material in the 20's.
ph.Dmechanical / manufacturing engineering.
Razziel24
Guayaquil
Explorer 2012 3.5 V6 Base
20´s FTW !!!
Get them, youll never regret it, they look awesome, the limited comes with 255/50R20, its not like you are getting 35 or a 30 sidewall.
My uncle has a CX9, with the standard 20´s, with no problems at all.
Im still waiting for my xplorer, but I already got the 5 spoke 20's from the limited (great ebay deal by the way) with 4 255/50R20 Continental CrossContact UHP's, theyre sitting on my garage :D
rescue_31
Chicago
2011 XLT
I want the 5 spokes also, just havent been able to hunt them down.
11Limited
MN
2011 Limited
Even if you wanted to change now, your stuck.
Your vehicle is locked in, no changes would be allowed as all parts have been allocated.
I agree with the others, the 20's are for appearance sake only.
yow04xplr
Ottawa, ON
04 EB, 11 LTD
Not sure if this matters, but on page 7 of the owners manual it states.......
"Notice to owners with 20 inch wheels and tires. When equipped with 20 inch wheels and tires the vehicle is designed for on-road use only and not off-road use."
JDraper
Somewhat Functional
Moderator Emeritus
McVeytown, PA
'18 XLT
That statement is to protect Ford in case the rim gets dinged offroad because of the lower profile tire and subsequent increase in the potential for rim damage. "We told you it wasn't for offroading".....
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
This isn't necessarily true, I was able to add the inflatable seatbelts 3 weeks after the dealer submitted the order. You don't know unless the dealer attempts it.. the system will either say no or "pending plant approval".
This is a minor feature that wouldn't screw up the assembly line order.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I doubt they will do this at the factory. Inflatable seat belts is an available 'option', ordering a different size wheel is not.
tomg4121
SE PA
2011 XLT
Razziel24,
What kind of deal did you get on the rims on Ebay? Also, how are you comensating the speedometer on the vehicle with different size wheels then what it came from the factory with? I'm contemplating this change on mine by the way.
11Limited
MN
2011 Limited
You very well may have added the seat belt option. But your order wasnt scheduled and finalized yet. Yes you can make changes after you order, but before the vehicle is finalized.
This members vehicle is being produced this week. There is no way he is going to get that option added on that vehicle as that vehicle has been finalized for some time.
peterk9
Staff member
Moderator
Callsign
VE3
peterk9
Staff member
Moderator
Callsign
VE3
As I mentioned in another post, I doubt you can request the 20" wheels since they are not an 'option' available for the XLT. If wheels were an option, I probably would have ordered 17" ones for my Limited. Much less expensive tires and likely a little better ride.
usranger80
Augusta, GA
2011 Explorer Base
I'm a bit curious how they can already offer reconditioned 2011 Explorer wheels when the originals have only been out for a few months. Exactly what was the problem with these reconditioned wheels in the first place?
No idea, it was just the only place I could find anything at all, I haven't called them yet either, just wanted to put that option out there if someone wanted to give it a shot.
Razziel24
Guayaquil
Razziel24,
Hi, I got them on ebay for $800, brand new, from a guy who went aftermarket.
And then I bought the tires from tirerack.com
I ordered the same tire size the LTD version comes with (NOT hankook), so theres no noticeable overall diameter, heres what I got from the tire size calculator...
Original tire (245/60R18)
Sidewall: 5.79 in
Radius: 14.79 in
Diameter: 29.57 in
Circumf: 92.91 in
Revs/mile: 681.94
New Tire (255/50R20)
Sidewall: 5.02 in
Radius: 15.02 in
Diameter: 30.04 in
Circumf: 94.37 in
Revs/mile: 671.39
Speedometer reading with new tire is 1.57% too slow.
When your speedometer is reading 60mph you are actually traveling 60.93mph
I can live with 1.57% :)
M Sport wheels and tires with Ford tire sensors Stock 2011 - 2019 Ford Explorer Discussion 7
D Black Wheels Stock 2011 - 2019 Ford Explorer Discussion 0
D Will 265/65R18 fit on stock wheels with leveling kit on 2014 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 0
L Great looking Wheels Stock 2011 - 2019 Ford Explorer Discussion 5
C New Wheels Questions. HELP ME Stock 2011 - 2019 Ford Explorer Discussion 9
J 2014 FWD Explorer - Rear Wheels Spinning Stock 2011 - 2019 Ford Explorer Discussion 23
S 2020 Explorer 21" Aluminum Wheels Compatability Stock 2011 - 2019 Ford Explorer Discussion 5
K 20" Premium Black Aluminum Wheels on 2019 Sport Stock 2011 - 2019 Ford Explorer Discussion 2
A Wheels that will clear the big brakes? Stock 2011 - 2019 Ford Explorer Discussion 1
M 18" wheels on a Sport? Stock 2011 - 2019 Ford Explorer Discussion 18
S Interceptor wheels? Stock 2011 - 2019 Ford Explorer Discussion 0
R Anyone running F-150 Wheels on their 2018 Explorer? Stock 2011 - 2019 Ford Explorer Discussion 17
G Full size spare for 15 limited w/20" wheels Stock 2011 - 2019 Ford Explorer Discussion 3
1 Wheels Stock 2011 - 2019 Ford Explorer Discussion 4
S Ford Explorer smaller wheels any benefit? Stock 2011 - 2019 Ford Explorer Discussion 14
D 5x115 wheels ? Do they fit Stock 2011 - 2019 Ford Explorer Discussion 8
Dan17ExpLtd Show me your wheels? Stock 2011 - 2019 Ford Explorer Discussion 31
1 2013 Ford Explorer Limited 4X4 dingy flat towed, 4 wheels down Stock 2011 - 2019 Ford Explorer Discussion 0
C 17" wheels on a 2014 Limited Stock 2011 - 2019 Ford Explorer Discussion 2
K Separate wheels/tpms, definitive edition for 2016+ explorers. Stock 2011 - 2019 Ford Explorer Discussion 41
E Police Interceptor Wheels & Sport Stock 2011 - 2019 Ford Explorer Discussion 29
C Swapping 20" wheels for 18"? Stock 2011 - 2019 Ford Explorer Discussion 22
1 Clicking front wheels Stock 2011 - 2019 Ford Explorer Discussion 21
T 2011-2017 wheels same pattern? Stock 2011 - 2019 Ford Explorer Discussion 20
D 2017 Wheels on a 2014 ---->TPMS ??s Stock 2011 - 2019 Ford Explorer Discussion 11
S 2015 wheels on a 2014? Stock 2011 - 2019 Ford Explorer Discussion 3
J Explorer wheels Stock 2011 - 2019 Ford Explorer Discussion 3
S Best Place for OEM Wheels Stock 2011 - 2019 Ford Explorer Discussion 25
T TPMS On after market wheels Stock 2011 - 2019 Ford Explorer Discussion 8
expoman55 Interested in a swap explorer wheels for Carol Shelby ? Stock 2011 - 2019 Ford Explorer Discussion 2
X Wtb oem sport wheels Stock 2011 - 2019 Ford Explorer Discussion 7
N 18" or 20" Wheels?!?!?! Stock 2011 - 2019 Ford Explorer Discussion 60
M Sport 4WD front/rear weight distribution on wheels Stock 2011 - 2019 Ford Explorer Discussion 14
1 How big can you go with 18" wheels? Stock 2011 - 2019 Ford Explorer Discussion 43
A 2014 Explorer Sport Wheels Stock 2011 - 2019 Ford Explorer Discussion 1
M abs light on after replacing rear rotors and pads all wheels Stock 2011 - 2019 Ford Explorer Discussion 1
S 2013 Explorer Sport "ticking" sound when turning wheels? Stock 2011 - 2019 Ford Explorer Discussion 11
X 2011 Limited Wheels Stock 2011 - 2019 Ford Explorer Discussion 16
Levittown Ford Parts Police Interceptor Wheels Stock 2011 - 2019 Ford Explorer Discussion 11
D 2014 explorer xlt 18" wheels 4wd Stock 2011 - 2019 Ford Explorer Discussion 10
B 2014 New Owners - Check Your Wheels when you pick up your new ride.. Stock 2011 - 2019 Ford Explorer Discussion 52
A 20'' OEM Wheels - Advice Needed! Stock 2011 - 2019 Ford Explorer Discussion 7
C 2013 Explorer Sport: Anyone with aftermarket wheels Stock 2011 - 2019 Ford Explorer Discussion 13
T Show your Aftermarket Wheels Stock 2011 - 2019 Ford Explorer Discussion 3
W Want to sell those factory wheels Stock 2011 - 2019 Ford Explorer Discussion 1
H just noticed my wheels are all damaged Stock 2011 - 2019 Ford Explorer Discussion 14
D looking for pics of '11-'13 Explorers with custom wheels and suspension mods Stock 2011 - 2019 Ford Explorer Discussion 2
D Will Mustang/Shelby wheels fit the our new Explorer? Stock 2011 - 2019 Ford Explorer Discussion 4
E Battery Drain when Recreational Towing 4 wheels down. Stock 2011 - 2019 Ford Explorer Discussion 2
T Aftermarket wheels/tires... Stock 2011 - 2019 Ford Explorer Discussion 19
Similar threads
