180,000 and going strong!
9COOP5
Ohio
2002 Exp XLS
2014 Exp XLT
180,000 miles on my ‘02 XLS Explorer and still going strong I hope. Just went over 180k today, hope to get to 190k then to 200k!
IIGood
Arnold, MD
03 Explorer; 03 Mustang
Keep up on the maintenance and you'll be good to go! I'm coming up on 209K on my '03 XLT and it's still going strong as well. I had 334K on my previous '03 XLT...a deer killed that one though.
Both of them are even the 4.0L V6!
9COOP5
Ohio
2002 Exp XLS
2014 Exp XLT
Wow IIGood 334k! Yea my 4.0 is doing well.
07gtman
Chicago IL
2005 Mountaineer 4.6 AWD
Good luck on many more miles.still looks good
blabla
Autism, Texas
2002 Explorer XLT
Be aware that the oil gauge is a 5psi switch
Drewmcg
Location
Michigan
Ann Arbor, MI
2010 XLT 4WD
2002 XLS 2WD
Congrats. If you're front wheel bearings are original and you plan on any long trips, you might want to change them out first. My '02 white XLS (looks like yours) 2wd just had both go out within a few hundred miles of one another at 195k miles. Doable DIY repair at home, but not on the road! Cheers.
Hitchhikingmike
Dallas, Texas
'02 XLS
great! I like seeing older cars still working well. I have 145kmi on my '02. Still has untouched timing chains and original transmission.
fireball 440
Location
Northern MN
minnesota
2015 Police Interceptor
182K on my 2005 Explorer. Just got done replacing the rear window hinges and a fresh Spring detail and wax job. She's had a whiney rear end and a 3-4 shudder for the last 5 years, still driving it 300+ miles a week my daily driver. Replaced the front wheel bearings a couple times & all 4 wheel speed sensors, temp blend motor, sway bar links, still driving with a broken front coil and the rear wiper doesn't work. The rest has all been preventive maintenance and wear items. Overall it's been good to me, I treat it nice... and when it's time I'll replace it with another Explorer.
RogerB1
2005 Mercury Mountaineer
My 2005 Mountaineer has 164K. Recently it shut down on me on the interstate and went into failsafe mode. Dealer replaced crankshaft pulley, sensor, and belt. In the past two months or so I have myself replaced the EGR valve, the entire wiper fluid reservoir, liftgate supports, front wheel bearings, and all the sway bark links. I still like it, but I am starting to see all kinds of leaks underneath.
Drewmcg
Location
Michigan
Ann Arbor, MI
2010 XLT 4WD
2002 XLS 2WD
I have a 2002 XLS (195k miles). I wonder whether it has a failsafe model. Seems like more hassle than it's worth.
N1265
Fremont Oh
'04 explorer
2004 4.6 with 186k,
rear wheel bearings,
rear lateral links ,
rear pinion bearing,
alt,
blend door fix,
I got 300k out of my 1996 explorer with only replacing wheel bearings, ball joints, alternator and 2 torque converters, and hope to get 300k out of this one...
S Help 2002 Explorer V6 4.0L SOHC 180,000 KMS Stock 2002 - 2005 Explorers 5
M power steering fluid leak 225,000 Miles Stock 2002 - 2005 Explorers 1
H what to service at 185,000 miles ? Stock 2002 - 2005 Explorers 3
H 2004 XLT with original ATF 160,000 miles Stock 2002 - 2005 Explorers 3
I Just joined the 200,000 mile club Stock 2002 - 2005 Explorers 11
1996EB Just joined the 200,000 mile club! Stock 2002 - 2005 Explorers 6
C 2002 explorer transmission 170,000 miles Stock 2002 - 2005 Explorers 2
A 2003 V6 160,000 miles... Advice. Stock 2002 - 2005 Explorers 14
J 66,000 Maintainece Stock 2002 - 2005 Explorers 4
G Just had my transmission rebuilt at 220,000 miles! Stock 2002 - 2005 Explorers 2
R '03 XLT 4.6L V8 - 245,000 miles...no major issues Stock 2002 - 2005 Explorers 0
A Sold the '05 for $7,000. How did I do? Stock 2002 - 2005 Explorers 2
C Advice? 02 V8 w/ 164k asking $4,000? Stock 2002 - 2005 Explorers 4
E My 2003 engine at 115,000 miles is about to die. Stock 2002 - 2005 Explorers 1
R 03 explorer 107,000 4x4 question Stock 2002 - 2005 Explorers 3
E 02 Explorer 4x4 Eddie Bauer 4.0L SOHC 130,000 mi Stock 2002 - 2005 Explorers 1
E What to do for 100,000 mile maintenance Stock 2002 - 2005 Explorers 3
2 $600-$1,000 for a lift gate that is ALSO cracked? SERIOUSLY??? Stock 2002 - 2005 Explorers 5
R What should I know about doing a 100,000 mile service? Stock 2002 - 2005 Explorers 4
S Broken Timing Chain on 4.0L after 40,000 miles Stock 2002 - 2005 Explorers 5
P Question about 100,000 mile service? Stock 2002 - 2005 Explorers 13
G transmission flush over 100,000 miles? Stock 2002 - 2005 Explorers 2
J 2002 Explorer with 160,000 Stock 2002 - 2005 Explorers 9
J 110,000 miles original fuel filter Stock 2002 - 2005 Explorers 20
J 2002 Explorer 4x4 4.0 auto, 100,000 miles Stock 2002 - 2005 Explorers 4
S Axle Failing 16,000 after Full TSB Rebuild Stock 2002 - 2005 Explorers 5
D 70,000 miles what needs to be checked for maintanance? Stock 2002 - 2005 Explorers 0
R 40,000 Mile Service Recomendations Stock 2002 - 2005 Explorers 0
D 2004 Brakes at 50,000 highway miles? Stock 2002 - 2005 Explorers 9
S 2002 31,000 miles needs new engine !!! Stock 2002 - 2005 Explorers 4
F 100,000 Mile Spark Plugs ??? Stock 2002 - 2005 Explorers 43
2 is synthetic okay at 5,000 mile oil change? Stock 2002 - 2005 Explorers 13
S Keep going or sell? Stock 2002 - 2005 Explorers 0
A Blower motor whines when going over bumps. Stock 2002 - 2005 Explorers 0
T Car Alarm Keeps Going Off Stock 2002 - 2005 Explorers 2
W Surging with cruise when going downhill solved Stock 2002 - 2005 Explorers 0
W How to "Cap" coolant line going to rear heater core Stock 2002 - 2005 Explorers 1
L 2002 XLT rear window not going up Stock 2002 - 2005 Explorers 4
K factory alarm going off while charging battery Stock 2002 - 2005 Explorers 3
J Stability problem going down the road Stock 2002 - 2005 Explorers 1
9 Going over bumps or even roadways Stock 2002 - 2005 Explorers 3
H Brake Pedal Going To Floor After Starting Engine Stock 2002 - 2005 Explorers 5
G Help!! - "04" Explorer 2wd has a rubbing grinding noise going on in the front end Stock 2002 - 2005 Explorers 5
M 2004 Explorer Windows not going down & up Stock 2002 - 2005 Explorers 0
T Alarm going off every time I unlock the door… Stock 2002 - 2005 Explorers 2
W 03 Explorer 4wd 5r55w going into neutral while in drive or reverse Stock 2002 - 2005 Explorers 55
R Going to buy an '03 Aviator, any tips or info? Stock 2002 - 2005 Explorers 3
A 5R55W doesn't engage when going from P to D and P to R Stock 2002 - 2005 Explorers 24
J Transmission going bad? Stock 2002 - 2005 Explorers 7
T 2002 Alarm going off Stock 2002 - 2005 Explorers 0
Similar threads
