56explorer
- May 14, 2013
- Arkansas
- 56 F100 Explorer (96) XLT
Well, the kids are being quiet right now, not sure if that is a good thing, but I guess I have time to get more on here.
The removal of the rear half was a bit challenging. The fuel tank had to be removed so I didn't blow up my shop. I started with the filler cap, neck and tubes.
Unbolted the strap
and removed the front two bolts to let down the front side to gain access to the other stuff.
You will NEED this tool to remove the fuel lines from the tank
Then onto the big piece. 2 of the 4 bolts came out without fuss...
The other two...
...needed a little extra convincing. The bushings that retain the "nut" are no longer holding in place and continue to spin when I turn the bolts. So they were extracted by other means.
I would rather have more material than to cut the floor too short, so this was the point I decided I'd cut, marked with tape for reference.
When I measured the 56 cab, it was 48 inches from the front to back from the points I decided could be measured comparably. This seam was very close, but I added another 12 to be safe, plus I might attempt to utilize the studs in the floor to help mount some of the electronics behind the seat. (computer, keyless entry box, etc)
This monster came from Harbor Freight Tools for $19.99 and was stronger and tougher than I imagined it being for that price.
While I was there I also picked up this lowrider creeper for the same price
My first cut
Careful, don't cut the frame or anything else. I removed the rear wheels for easier removal of the body.
Voila
Unbolted the strap
The other two...
My first cut
Voila
Thanks for the detailed photos.
