Thedentedcan
- April 22, 2013
- Fort Worth, Tx
- 1991 Explorer XL 5sp 4x4
Howdy, new user and Explorer owner here.
I just picked up a 1991 XL 4X4 5speed, and I'm having a blast with it. I do however have one issue, and despite extensive searching I can't seem to find a solution. I have a high idle (tach shows 1000-1200k) at all times, cold and warm. I have already replaced IAC after not being able to clean the old one to my liking. My MAF is clean and I put new gaskets on the throttle body and IAC. the part that doesn't make any sense to me, is that I can get it to idle down to about 6-800 RPM by pressing the clutch in. For example, if I am slowing down to a stop and I press the clutch and shift to neutral, the engine revs to 1200 rpm. Once stopped I can press the clutch for a couple seconds and the engine will idle down to normal. I am on the verge of replacing the TPS just to see if that helps any, however I can't think of how the clutch would affect the engine idle in neutral. Does anyone have any ideas?
Thanks in advance for any help. I'm looking forward to getting her running smooth so I can hit some dirt soon
