tireman406
- April 2, 2013
- Boise, ID
- 1991 Explorer XL
I work at an auto shop. Yesterday morning on my way to work my cel came on and went off and came on... scanned and it pointed to maf. Removed it cleaned it replaced it. Started it up drove fine no cel. Later in the day i pulled it up on our lift for a little under car tlc with degreaser and our preasure washer. After finishing my cleaning job lowered vehicle back down and fired it up. It will not rev, push in on the gas pedal and the motor starts to rev and drop rev and drop. After a minute or so it will stabilize on its own but the next time you hit the gas it does it again. Tried recleaning the maf and it didnt change. With the motor running unhooking the maf doesnt change the idle at all. Called our parts house had a new maf sent over. Plugged it in no change as far as running. Replaced old maf.
Does anyone know if you can check the wiring between the maf and the pcm to insure the signal from the maf is being sent to the pcm? I know that in the past when i have unplugged my maf the vehicle will just die. It is running like it did when i got water up through my airbox onto my maf and had to wait until it dried out for the vehicle to return to normal running conditions. I also cleaned out the iac and tps from the insidde of the intake and am wondering if maybe a piece residue could be causing this issue.
Ok long thread short do you have any ideas as to what i could try next? I am going to test the maf in the morning to ensure it has 12v, ground, pcm ground, and voltage fluctuation while running. I also went back under the vehicle and made sure all wires were connected.
Thank you in advance if you have any ideas.
