Ixxy
- January 31, 2011
- Florida
- 1991 explorer 4.3
I have a 1991 Ford Explorer 6cyl 4.3. It started running rough and idling funny, then eventually it wouldnt start at all. I have to squirt a little starter fluid into the injector to get it to fire. It will then run rough and eventually it will make a weird jerk and then idle normal and the engine light shuts off. But the next day its a rinse and repeat deal. I have replaced the fuel pump, filter and the fuel regulator and its still the same deal. I can unplug the mass flow sensor and the truck continues to run. I was going to go buy a code sensor and see what it said but my brother thinks it could be a bad computer, he said if the computer is bad it may tell me false info. Has anyone else encountered this problem? Also I have put in a new water pump, power steering pump, plugs and wires and air filter.
