The other question is whether or not your rig will be off the road much...if it's a build just for show, there are ways you can do that just to reach that point, but if it's a build purpose-built for wheeling, there are some other ways you could go about the process. It also depends on the off-road purpose of the truck..."rock crawling" or pre-running. if it's a trail rig you want, and you're looking towards some more hard-core stuff, solid is your best bet (although there are some good links on here on how to get a TTB set up very well for trail) and the TTB is good for desert. Cut & turned TTB's and lift coils are a good option in that aspect.
Seeing as you're a VA man, I'm gonna guess pre-running isn't really what you have in mind for your EB....the next questions then become; what's the level of wheeling your looking to do? Is there a specific tire size you're wanting to run? Is this on a tight budget or do you not have a limit on your bank account? There are plenty of builds on here for those with big accounts and builds done on the cheap....personally, mine is gonna be on the cheap (including re-gearing and costing less than $500 before tires) but from research on this site, should be a recipe for a good trail rig (just waiting for a bit of cash flow to start.)
