1991 explorer build ttb44 & LS Swap
daygor87
chula vista
91 explorer eddie bauer
hello thanks for the add ive recently purchased a 91 explorer 113k miles from original owner. needed water pump radiator and thermostat , valve covers when i first purchased .ive been gathering parts for the last 2 months or so , ive got giant d44 conversion mountsfor the front and for rear 9' with 3 link setup, fuel cell , waiting on fiberglass 6" front and 7" rear fiberwerx to be done so i can throw the front stuff on my original plan was to do an 6.0 lq4 swap and 4l80e since i have it in my other project that ive lost interest in (85 k5 blazer ) , but doing a 5.0 with fi-tech style carb is what im leaning towards now right now just seems right to keep ford a ford lol im not a sack religious guy i enjoy ls swaps in everything, if anyone has input in that swap or links i will greatly appreciate it , i will either do the swap before the suspension is on or after needs to be 4wd
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
Blue m&m
Athens, GA
94 Sport 4X4
92 Eddie 4x4
fordpickupman
Cascade, ID
94 XLT
71 F250 Fummins
Daaaang, I'm liking where this is going. Subscribed. I love TTB builds.
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
So much want!!
fordpickupman
Cascade, ID
94 XLT
71 F250 Fummins
I love seeing parts stashes in the living room. If I lived closer I'd want those centerline convo ht wheels.
daygor87
chula vista
They will be available once I start taking parts off hopefully in the next week or so
daygor87
chula vista
Small update time to follow the wiring thread haha will be spraying it black tomorrow , happy so far
fordpickupman
Cascade, ID
94 XLT
71 F250 Fummins
The shipping to Idaho would kill it for me.
I'm excited to watch this rig shape up. The parts pile is adding up to a high class build.
daygor87
chula vista
They fit good gotta wire up hopefully tomorrow if not I’ll do it during the week after work , had to help a buddy install a LT kit on his Toyota
daygor87
chula vista
Picked up my fiberglass from FiberwerX got quick release mounted also and some new headlights and clear corners ended up going with the Hikari LED bulbs for the headlights it amazing I can actually see at night
Exploring XLT
Never Stop Explorering
Location
Stony Plain, Alberta, Canada
93 Ford Explorer XLT 4WD
I love the headlight housings, what brand are they?
410Fortune
Flood Season
Staff member
Moderator
NORTH IDAHO, 7B
looks really nice! Do you plan to add indicators for the turn signals? Just curious
mounty71
It's green, not gray.
Oakland, CA
'00 Mountaineer
You are not kidding around with that pile of parts you’re accumulating! Looks like it will be a fun build. What’s the plan for the rear with the 3-link and the lower links you have pictured? Coilovers mounted on the axle? And keeping the stock frame or doing a full back half? My friend has a very similar setup to what you’re after. LS swapped, Giant D44 conversion, and a full back half pretty much from the B pillar back and I think a 32 gallon fuel cell at the back. His engine is pretty far back so he also had to do a custom firewall and custom headers. I’ll try and answer any questions you have.
daygor87
chula vista
I’m up in the air about the rear setup of coils on axle once the glass is mounted we’ll be able to see where the axle will land and the shock placement,I want to keep the back seat so that will be a big factor, and I plan on keeping the frame no chopping it up yet , as far as the swap it will be done after all the suspension is done I’m actually going to end up selling the lq4 and 4l80 if and when it does sell I’ll probably go with a 5.0 swap instead, I will also be running a 32 gal fuel cell in back can’t thorw that in yet because I need to be able to move the k5 within the next couple wheels when guy comes take the body and frame.
  • Like
Reactions: ~X~
allmyEXes Slightly Modified-1991 Explorer 4 dr 4x4 Build Modified 1991-1994 Explorers 19
B 1991 explorer build questions Modified 1991-1994 Explorers 6
E Brainstorming: Modified Explorer Sport 1991, what do to next? Modified 1991-1994 Explorers 6
allmyEXes 1991 Explorer 4dr 4x4 radiator option Modified 1991-1994 Explorers 2
J 1991 explorer alignment issues Modified 1991-1994 Explorers 3
J 1991 Explorer lift? Modified 1991-1994 Explorers 3
C Project Rebuild 1991 Ford Explorer XL Modified 1991-1994 Explorers 2
M Will a 2004 motor fit my 1991 explorer 4.0 2dr ? Modified 1991-1994 Explorers 4
C Interchangeable parts for 1991 ford Explorer? Modified 1991-1994 Explorers 1
D Exhaust 1991 Ford Explorer Modified 1991-1994 Explorers 2
1 Just bought this 1991 explorer for $900 as is!!! Modified 1991-1994 Explorers 7
P 1991 explorer slight front lift need help Modified 1991-1994 Explorers 59
C lifting my 1991 2 door explorer Modified 1991-1994 Explorers 5
R 1991 ford explorer lift questions Modified 1991-1994 Explorers 3
D adding 16" tires to a 1991 explorer Modified 1991-1994 Explorers 0
1 5.9L CUMMINS 12V into 1991 Explorer Modified 1991-1994 Explorers 4
CJExplorer 1991 Ford Explorer Emblem to New Emblem Modified 1991-1994 Explorers 22
CJExplorer 1991-1994 Removal of Explorer Emblem Modified 1991-1994 Explorers 10
K Lowering a 1991 Ford Explorer Modified 1991-1994 Explorers 12
D SAS almost done 1991 Explorer Modified 1991-1994 Explorers 16
O 1991 explorer... Modified 1991-1994 Explorers 4
D 1991 Explorer XLT Modified 1991-1994 Explorers 19
P Pphillips250’s 1991 Eddie Bauer build/ 1993 xlt story Modified 1991-1994 Explorers 3
C 1991 X, 4wd lift brackets on a 2wd? Modified 1991-1994 Explorers 0
J 1991 exploder 4 inch lift. 4x4 problems Modified 1991-1994 Explorers 7
9 Lifting a 1991 Navajo need answers Modified 1991-1994 Explorers 8
1 1991-1994 A4LD transmission - Need info Modified 1991-1994 Explorers 2
G 1991/1999 compatibility Modified 1991-1994 Explorers 4
R 1991 Ranger Tranny Rebuild Modified 1991-1994 Explorers 4
R 1991 xlt rear leaf springs Modified 1991-1994 Explorers 1
T 1991 Mazda Navajo rear diff question Modified 1991-1994 Explorers 19
J 1991 Mazda Navajo LX Modified 1991-1994 Explorers 0
L lift kit on my 1991 Navajo Modified 1991-1994 Explorers 7
A 1991 4.0l Camshaft kit Modified 1991-1994 Explorers 2
N 1991 mazda navajo Modified 1991-1994 Explorers 5
R 1991 Navajo lift, performance questions Modified 1991-1994 Explorers 1
O 1991 performance heads Modified 1991-1994 Explorers 11
B 1991 5th gear/reverse update Modified 1991-1994 Explorers 1
T My $100 X 1991 4x XLT Modified 1991-1994 Explorers 6
fiftyfordfloored 1992 -> 1991 Computer Swap - Merits? Modified 1991-1994 Explorers 2
CJExplorer First Generation Ford Explorers (1991-1994) FaceBook Group Modified 1991-1994 Explorers 0
A 1991 Lift Kit Modified 1991-1994 Explorers 16
C Will These Wheels Fit my Explorer? Modified 1991-1994 Explorers 0
L 1992 explorer front diff upgrades>? Modified 1991-1994 Explorers 24
C First Gen Explorer Roof Rack? Modified 1991-1994 Explorers 2
1 Is 5 inch lift on 94 explorer enough for 34's? Modified 1991-1994 Explorers 13
Hossexplorer Cool Explorer Youtube Video Modified 1991-1994 Explorers 2
M 1992 Explorer wiring Modified 1991-1994 Explorers 1
S 1994 ford Explorer XLT Colorado Modified 1991-1994 Explorers 4
Z Debadge 1994 Explorer Modified 1991-1994 Explorers 6
Similar threads
