- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
It sure did! Don't tease, do tell!!
hey i still go the wheels tried to text u but u never text back lolNice, this thing is coming along good!
I really like that setup! should ride awesome and with d44 spindles and wheel bearings it should hold up really well. I am very tempted to go d44 ttb if I didnt already have so much invested in my d35 (gears/ locker)
What kind of wheel studs are those?
the round airbox style intake tube is far superior to the 3 piece 91-92 tube! You will not have air leaks with that setup
Got the fuel cell in and Plumbed in its temporary location till it gets mounted correctly, pulled old tank and lines out , slowly but surely moving forward
I’ll figure that out when it’s time to smog it lolHow's that going to work with smog?
looks like 95-up 4.0 OHV setup
I believe it was a 2000 explorer I had to swap the ends and the actual sensor and it works fine
Not trying to hijack, but can you just swap the intake straight across from second Gen to first gen?
