xwray
- July 30, 2010
- spring, texas
- 1991 eddie bauer
Truck stalls on deceleration and idles erratically. Have changed plugs, air filter, fuel filter, crank sensor, cleaned MAF, IAC, throttle body. Computer codes are 14 and 66. Took to reputable mechanic and they tested computer and said was transmission problem. Took to transmission mechanic and he said transmission tested fine. First mechanic checked again and this time transmission was not part of codes. He said to take to Dealer for checkup. Called local ford dealer and they said that they don't check vehicles before 1995. Checked for vacuum leaks and found none. Checked wiring harnesses and they seem to be fine. Of special note: this problem started after there was an oil leak threw the oil pressure sensor. Any suggestions?
