1991 Explorer lift?
Jimmydean
Lehi, UT
1991 sport xlt
Hey, I found a 91 explorer sport 2d 4wd, and Im gonna buy it. Its completely stock and I was curious if this f-150 lift kit (here) would work on it and if so could I get 31" or 33" mudders on it. any information or tips would be greatly appreciated thanks!
allmyEXes
Location
Lickskillet
No. Alabama USA
'97 Merc "MO" the 5.0
Callsign
KAGG 3611
I would like to have those kits if necessary however it looks as if my 91 4x4 sits up a little better than my two 2WDs. I want 31s or 32s and have decided that I am going to do a 2" BODY LIFT. It doesn't cost much and if it is kept at 2" then there isn't much of a steering shaft modification issue. Also 2" is a good modification to go with a 302/5.0 upgrade.
Also I've read that wheel spacers could help with tire rub like that could happen using these Nankangs
http://www.ebay.com/itm/1-New-32X11...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
420kipper
92 explorer xl
I got 31s on mine stock. And spacers might increase rub
P 1991 explorer slight front lift need help Modified 1991-1994 Explorers 59
R 1991 ford explorer lift questions Modified 1991-1994 Explorers 3
E Brainstorming: Modified Explorer Sport 1991, what do to next? Modified 1991-1994 Explorers 6
D 1991 explorer build ttb44 & LS Swap Modified 1991-1994 Explorers 141
allmyEXes Slightly Modified-1991 Explorer 4 dr 4x4 Build Modified 1991-1994 Explorers 19
allmyEXes 1991 Explorer 4dr 4x4 radiator option Modified 1991-1994 Explorers 2
J 1991 explorer alignment issues Modified 1991-1994 Explorers 3
C Project Rebuild 1991 Ford Explorer XL Modified 1991-1994 Explorers 2
M Will a 2004 motor fit my 1991 explorer 4.0 2dr ? Modified 1991-1994 Explorers 4
C Interchangeable parts for 1991 ford Explorer? Modified 1991-1994 Explorers 1
D Exhaust 1991 Ford Explorer Modified 1991-1994 Explorers 2
1 Just bought this 1991 explorer for $900 as is!!! Modified 1991-1994 Explorers 7
B 1991 explorer build questions Modified 1991-1994 Explorers 6
C lifting my 1991 2 door explorer Modified 1991-1994 Explorers 5
D adding 16" tires to a 1991 explorer Modified 1991-1994 Explorers 0
1 5.9L CUMMINS 12V into 1991 Explorer Modified 1991-1994 Explorers 4
CJExplorer 1991 Ford Explorer Emblem to New Emblem Modified 1991-1994 Explorers 22
CJExplorer 1991-1994 Removal of Explorer Emblem Modified 1991-1994 Explorers 10
K Lowering a 1991 Ford Explorer Modified 1991-1994 Explorers 12
D SAS almost done 1991 Explorer Modified 1991-1994 Explorers 16
O 1991 explorer... Modified 1991-1994 Explorers 4
D 1991 Explorer XLT Modified 1991-1994 Explorers 19
P Pphillips250’s 1991 Eddie Bauer build/ 1993 xlt story Modified 1991-1994 Explorers 3
C 1991 X, 4wd lift brackets on a 2wd? Modified 1991-1994 Explorers 0
J 1991 exploder 4 inch lift. 4x4 problems Modified 1991-1994 Explorers 7
9 Lifting a 1991 Navajo need answers Modified 1991-1994 Explorers 8
1 1991-1994 A4LD transmission - Need info Modified 1991-1994 Explorers 2
G 1991/1999 compatibility Modified 1991-1994 Explorers 4
R 1991 Ranger Tranny Rebuild Modified 1991-1994 Explorers 4
R 1991 xlt rear leaf springs Modified 1991-1994 Explorers 1
T 1991 Mazda Navajo rear diff question Modified 1991-1994 Explorers 19
J 1991 Mazda Navajo LX Modified 1991-1994 Explorers 0
L lift kit on my 1991 Navajo Modified 1991-1994 Explorers 7
A 1991 4.0l Camshaft kit Modified 1991-1994 Explorers 2
N 1991 mazda navajo Modified 1991-1994 Explorers 5
R 1991 Navajo lift, performance questions Modified 1991-1994 Explorers 1
O 1991 performance heads Modified 1991-1994 Explorers 11
B 1991 5th gear/reverse update Modified 1991-1994 Explorers 1
T My $100 X 1991 4x XLT Modified 1991-1994 Explorers 6
fiftyfordfloored 1992 -> 1991 Computer Swap - Merits? Modified 1991-1994 Explorers 2
CJExplorer First Generation Ford Explorers (1991-1994) FaceBook Group Modified 1991-1994 Explorers 0
A 1991 Lift Kit Modified 1991-1994 Explorers 16
Y Turbocharged first gen Explorer pics Modified 1991-1994 Explorers 9
BKennedy Oldest and Latest Pictures of Your Explorer Modified 1991-1994 Explorers 23
Y F150 coil seats question?? With stabilizer bar on my 92 explorer 2wd Modified 1991-1994 Explorers 23
E Modified Twin Size Bed First Gen Explorer Modified 1991-1994 Explorers 2
C Will These Wheels Fit my Explorer? Modified 1991-1994 Explorers 0
L 1992 explorer front diff upgrades>? Modified 1991-1994 Explorers 24
C First Gen Explorer Roof Rack? Modified 1991-1994 Explorers 2
1 Is 5 inch lift on 94 explorer enough for 34's? Modified 1991-1994 Explorers 13
Similar threads
