1991 Explorer. Problem with stereo wiring. | Ford Explorer Forums - Serious Explorations
aliotrunco
aliotrunco@GMAIL.COM
this is the only wiring diagram I can find:
Car Radio Battery Constant 12v+ Wire: Light Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Light Blue/Red
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Blue
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Pink/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Light Green
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Black/White
everything on it matches up except the speaker wires.
My explorer's speaker wires are:
white orange
white red
purple white
light blue
light blue black
yellow
green
brown
and I have a random unidentified thick red wire.
I have used trial and error with all of the wires, and still cannot get a single speaker to make a sound. I have installed this same head unit in a honda accord, a dodge dakota, and a jeep wrangler without issue. is anyone has any tips they would be greatly appreciated.
Welcome to this forum! I've renamed your thread, and moved it into the audio & navigation section. Check WWW.The12Volt.Com for a schematic diagram.
What type of OEM stereo was in the truck? Was it the AM/FM/Cassette with a toggle type volume switch? If so, the truck has an external amplifier that needs to be bypassed. The factory amp is behind the passenger side trim in the cargo area, right above the wheel. Here is a link which has pictures of where the amp is located. Crutchfield has a wiring harness that you can use to bypass this amp. Once the amp is bypassed you can use a 9 volt battery to verify speaker connections by quickly touching the wires to the battery. You will hear a pop from the speaker if you have the correct wires.
