1991 explorer stereo wiring / no sound
no sound 91 explorer
  • retwerw
    Votes: 0 0.0%
  • wrytwet
    Votes: 0 0.0%
  • Total voters
DAVID MAN
DALY CITY
1991 ford explorer
hi people, Im Dave, I owned a smog shop here in california for 20+ years, i am retired and feel stupid for this issue, I put a sony in my 91 explorer, and no sound from speakers???? followed wire diag. 5.9v from head unit to doors?? Whats up?
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Did you OEM radio have a amp located under the right rear cargo interior panel? If so, you might need to bypass that. Did you use an adapter wiring harness, or cut the OEM sheathed wires? Its always better to leave the OEM wiring in place and get adapters.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
Most likely have a factory amp. It can be retained, but I would bypass it or run new wires to the doors. The factory amp doesn’t sound that great, and unless the radio you installed is very bottom line it’ll have just as much power.
Wilson Vo
Arlington, Texas
1991 Ford Explorer 4x4
@DAVID MAN
You could just buy a amp bypass wiring harness and remove to amp and just put that in that’s what I did on mine.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
The last time the OP logged on was at the same time the thread was created. I don't think he will be back to view this.
Wilson Vo
Arlington, Texas
My bad lol I’m still new to forum and all.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
No problem, you are right in that you can order amp bypass wiring and adaptor wiring for head unit. I did that probably 15 years ago with mine and keep using the same adaptor for new stereo's every few years. Wires are getting a little short, so might have to break down and spend $5-10 for next time.
Mbrooks420
High Voltage.
EF Vendor
Wilson Vo
Arlington, Texas
That amp in the quarter panel was a pita to get to though lol.
BKennedy
Elite Loser
Staff member
Moderator
Location
USA
San Diego, PRofK
1994 XLT
Not if you pull the panel off first, then its easy. I have one of those cheapo trim removal tool sets that makes it easy.
Wilson Vo
Arlington, Texas
Yeah that’s what I use got it from harbor freight but the darn panel clips broke lol.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
This quote plus a mention @DAVID MAN should send another email notification and get the OP attention.
D Urgent help needed. 1991 Explorer transfer case shift motor rebuild. Stock 1991 - 1994 Explorers 6
D Solved 1991 Ford Explorer Upstream O2 Sensor Stock 1991 - 1994 Explorers 3
P 1991 Explorer Won't Shift into OD Stock 1991 - 1994 Explorers 4
9 1991 Explorer 4x4 Pulling to the Right When Braking Stock 1991 - 1994 Explorers 3
G Querying 1991 Explorer electronics Stock 1991 - 1994 Explorers 12
D 1991 explorer opening the evaporator box? Stock 1991 - 1994 Explorers 8
J 1991 explorer sport 5spd manuel 2wd transmission/clutch Stock 1991 - 1994 Explorers 6
C 1991 Explorer XLT Voltage Ripple, Oscillation at speed or idle Stock 1991 - 1994 Explorers 7
C ECU! Explorer Eddie Bauer 1991! Help! Stock 1991 - 1994 Explorers 4
D 1991 explorer sport 4x4 rear lights Stock 1991 - 1994 Explorers 3
T 1991 ford explorer manual trans Stock 1991 - 1994 Explorers 4
S 1991 explorer front end questions Stock 1991 - 1994 Explorers 12
mr cribb 1991 Explorer Test from Motorweek Classic Stock 1991 - 1994 Explorers 24
S Exhaust Replacement on 1991 Explorer Stock 1991 - 1994 Explorers 7
B 1991-1994 Explorer Option of Keyless Entry Pad or Remote Stock 1991 - 1994 Explorers 8
G ExplorerForum vendor needs your voice! (1991-1994 Explorer) Stock 1991 - 1994 Explorers 48
B 1991 Explorer XLT ac recharge? Stock 1991 - 1994 Explorers 8
B 1991 Explorer XLT engine knock? Stock 1991 - 1994 Explorers 9
B 1991 Explorer can't begin driving in Overdrive Stock 1991 - 1994 Explorers 3
T Roof Rack for 1991 Ford Explorer Stock 1991 - 1994 Explorers 1
M Where is the cigarette lighter on 1991 Ford Explorer XLT ? Stock 1991 - 1994 Explorers 2
D 1991 Explorer won't start when hot Stock 1991 - 1994 Explorers 8
S 1991 Ford Explorer M50D Manual, changed fluid now reverse is bad Stock 1991 - 1994 Explorers 8
natenkiki2004 1991 Ford Explorer Owners Guide [Searchable PDF] Stock 1991 - 1994 Explorers 27
J 93 4.0 into a 1991 explorer Stock 1991 - 1994 Explorers 1
D 1991 Ford explorer humidity problems Stock 1991 - 1994 Explorers 2
L.A.X 1991 Ford Explorer Eddie B 4X4 Stock 1991 - 1994 Explorers 7
S 1991 Explorer won't start Stock 1991 - 1994 Explorers 13
D 911 situation on my 1991 ford explorer Stock 1991 - 1994 Explorers 17
L Starter Help- 1991 Explorer Stock 1991 - 1994 Explorers 2
B 1991 Explorer idle revving mystery Stock 1991 - 1994 Explorers 8
T Overheating on a 1991 Ford Explorer :( Stock 1991 - 1994 Explorers 27
T 1991 Ford Explorer Back up light problem Stock 1991 - 1994 Explorers 9
A early 1991 Explorer wiring Stock 1991 - 1994 Explorers 0
1 1991 explorer unkown noise Stock 1991 - 1994 Explorers 0
1 first car (1991 explorer) Stock 1991 - 1994 Explorers 0
C 1991 explorer oil psi guage Stock 1991 - 1994 Explorers 3
W 1991 Ford Explorer 4x4. Knocking with a temperature increase. Stock 1991 - 1994 Explorers 9
mr cribb How to: Change thermostat 1991 - 1994 Ford Explorer w/pcs Stock 1991 - 1994 Explorers 34
F My 1991 Explorer XL Is My Frankenstein Stock 1991 - 1994 Explorers 5
J 1991 explorer steering wheel melting ( ? ) Stock 1991 - 1994 Explorers 7
I 1991 Explorer, hubs engage on their own Stock 1991 - 1994 Explorers 3
S Engine trouble on 1991 Explorer Eddie Bauer Stock 1991 - 1994 Explorers 2
J 1991 2wd Explorer transmission tale of woe Stock 1991 - 1994 Explorers 3
H will 1996 ford ranger 2wd transmission 5 speed. fit a 1991 ford explorer 4wd Stock 1991 - 1994 Explorers 1
I 1991 explorer 4.3 6cyl possible computer prob. Need help. Stock 1991 - 1994 Explorers 5
P 1991 4x4 Explorer 4.0 V6 with an ignition issue. Stock 1991 - 1994 Explorers 1
M 1991 Explorer boils over after you shut it off -- FIXED Stock 1991 - 1994 Explorers 27
X 1991 Explorer is stalling on deceleration and has an erratic idle. Stock 1991 - 1994 Explorers 8
A 1991 Ford Explorer Security System Question Stock 1991 - 1994 Explorers 3
Similar threads
