Solved 1991 Ford Explorer 4.0L V6 oil filter removal.
Kcj
Grand Island
1991FordExplorer4DRSPUTIL
I can't get oil filter off. I tried a screwdriver in the bottom of it and still no luck. And why does the whole filter swivel up?
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
There is a 90 degree elbow adapter on the block so the filter points down. A Filter wrench cup socket is what I use with a ratchet or breaker bar.
Kcj
Grand Island
Thanks a lot! First ford and a little confusing.lol
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Kcj
Grand Island
Thanks for all your help. Much appreciated!
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
By the way, there is another filter that works on this engine and is 2" longer, which gives you better access and filter performance. It's the Baldwin BT251, and it still tucks up nicely but gives you better grip access, a little better oil cooling, and Baldwin is known for heavy truck industrial filters. They are available on Amazon for about $12.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
That is a good filter, Napa 1773 is a cross reference. I use it and like the extra oil capacity.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
If the filter mount is swiveling like @RangerX pointed out you will need to visit the mount. There are 3ea O rings in the 91 4.0 oil filter mount that like to dry up and develop leaks....good time to replace them. On some trucks you will have to loosen the exhaust Y pipe to get access
This is the style wrench I use:
45FF23_AS01
47 Knuckle
Independence, Kentucky
2005 Explorer XLT
Go to harbor freight and get this oil wrench! I had the same problem and this does the trick..You can get one like it from Hope Depot and its made by Huskey..
Pete Deering
Salem, nh
1995 xlt 4 door 4x4
Performance tool makes spring load oil filter wrench, as you turn the filter off it turns the whole filter and tightens up at the same time. They offer two sizes small and large. About $18 each. Bin using then a long time. Ebay or amazon is selling then
Roadrunner777
Bemidji, MN
94 4x4 Sport 88k
Only because it has happened to me when I don't have a good oriented view... Righty Tighty, Lefty Loosy
Try to get some kind of wrap-around strap wrench as close to the filter base as you can get it. Slow steady torque. I'm really surprised stabbing it through with a screwdriver didn't break it loose though, always my last resort, always worked.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
rgjusa
CA
92 Explorer EB
Don't forget to rub a little oil on the rubber seal when you put the new one back on again.
Kcj
Grand Island
Thanks for all the help! I thought Google was it. This forum rocks! I did get the oil filter off. It took a bicycle chain and a pair of vise grips, but hey it's off.lol
BrooklynBay
Staff member
Moderator
Brooklyn, NY
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Ive had the screwdriver trick fail before too.... and it was on a OHV where access sucks.
The driver just went through the whole filter body and then ripped it wide open all the way around....still filter did not turn.
That was the one time the screwdriver did not work
People turning the filter one more turn is not going to stop a leak its going to create new ones :) lol YOU do not need to hulk them into place
Hyde_Jeckyll
Crown King, Arizona
1991 & 1994 Ford Explorer
If you still can’t get it try close to the top of the filter with the screw driver and a bigger screw driver
umopepisdn
Spring Tx
99 Explorer XLT 4.0 sohc
I never have to use a tool to get my filter off. Just a dry towel and good ol hands. Filter should never be tightened using a tool. Just get it as snug as you can by hand. Then next oil change, you shouldn’t need a tool to remove it.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
You cannot get a screw driver into the filter high up on a OHV< there is not much room to work!
Yes you are supposed to hand tighten filter and then go 1/4 turn......
