a2m4m60
- January 1, 2007
- NC
- 1992 Ford Explorer
Hey all. I have a 1991 Ford Explorer with an odd problem. Every so often when the vehicle is in part with the key in the ignition the vehicle will start honking just like a newer vehicle would if the remote alarm was pressed. This will continue for a while till it stops or I press the lock unlock buttons back and forth.
Is there a wire or fuse I can take out to stop this problem? Has anyone else had this issue or am I the only one?
Also, on a side note, does anyone have a diagram for the lighting switch on the 1991-1994 explorer series with labels for the wire colors?
Thanks.
Thanks.
