1991 Ford XLT Brake Problems | Ford Explorer - Ford Ranger Forums - Serious Explorations
catfisher81
London, Kentucky
1989 Ford Ranger XLT
first off my brake pedal would have a lot of pressure when I would go to stop and I would actually not be able to stop my vehicle. So i decided to change my booster. My brake master cylinder is fine. I bleed the back right, front left, and front right, because the back left i am not able to get the bleeder loose. but when i am driving i hit the breaks i have not a whole lot pedal and it seems like when the vehicle is off i can pump the brakes and i get a stiff pedal, i mean super stiff pedal. but when i go hit the brakes the pedal is stiff, and will not stop on contact but as the pedal eases down it stops. i know i did not bleed the back left side, but what is the cause of all this.
________________________________________________________________
1991 4.0 xlt 4x4 5speed
106,055 miles on it. BFGOODRICH all the way around
New clutch,pressure plate, throughout bearing, and just replaced the clutch slave cylinder
new alt, starter, battery, selinoid on firewall, bosh platnum plugs, new wires.
==-=======I have put alot into this vehicle and i want a good brake system.
PLease help me..:usa:
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Back Left: Try Bleeding it by loosening the Steel Line. Pump up the pedal, hold it , and have someone crack the Line loose from the Wheel Cylinder , pedal goes down hold it while the Line gets tightened. repeat. this works fine on Drum Brakes
