for the rear, go pull out a 8.8 rear axle from a 2nd gen exploder. 3.73 or 4.10, whichever you want. if you ever want a locker, get an open axle. if you really want ls, get an ls.
with that axle, you will need a master cylinder from a 95 and ONLY a 95 exploder. with NO proportioning valve and NO cruise. thats the only one that will correct the braking power to match your new discs on the rear.
being you tow, rear discs will help. another thing, grab the sway bar from the 2nd gen axle also. its thicker and better.
as stated, its open if you spin one rotor forward and the other one goes reverse. and its ls if they both go the same direction. if only the one youre spinning spins and the other one sits there, leave and find another axle.
for the front. youre getting an open. no way around it. and only from a 91-94 first gen. if you got a rear 3.73 axle, get a 3.73 front pumpkin. just swap the whole thing to avoid setting the gears.
if you decide on 4.10 for the rear. buy the 4.10 online, reverse cut, and have someone put them in your current pumpkin. 1% chance youll find a 4.10 axle, im not sure they exist.
