1991 X, 4wd lift brackets on a 2wd?
Cameron42
Los Alamitos
1991 Ford Explorer XL 2wd
ive read all the threads on lifting a 1st gen X on here and can’t seem to pinpoint a solid answer for lifting a 2wd with 4wd lift kits. From what I’ve read it’s about 50/50 on yes or no on if the brackets will work, anyone on here have a 4” lift kit from rough country for 4wd on a 2wd X? Any feed back appreciated!
E Brainstorming: Modified Explorer Sport 1991, what do to next? Modified 1991-1994 Explorers 6
D 1991 explorer build ttb44 & LS Swap Modified 1991-1994 Explorers 141
P Pphillips250’s 1991 Eddie Bauer build/ 1993 xlt story Modified 1991-1994 Explorers 3
allmyEXes Slightly Modified-1991 Explorer 4 dr 4x4 Build Modified 1991-1994 Explorers 19
allmyEXes 1991 Explorer 4dr 4x4 radiator option Modified 1991-1994 Explorers 2
J 1991 explorer alignment issues Modified 1991-1994 Explorers 3
J 1991 Explorer lift? Modified 1991-1994 Explorers 3
J 1991 exploder 4 inch lift. 4x4 problems Modified 1991-1994 Explorers 7
C Project Rebuild 1991 Ford Explorer XL Modified 1991-1994 Explorers 2
M Will a 2004 motor fit my 1991 explorer 4.0 2dr ? Modified 1991-1994 Explorers 4
C Interchangeable parts for 1991 ford Explorer? Modified 1991-1994 Explorers 1
D Exhaust 1991 Ford Explorer Modified 1991-1994 Explorers 2
9 Lifting a 1991 Navajo need answers Modified 1991-1994 Explorers 8
1 Just bought this 1991 explorer for $900 as is!!! Modified 1991-1994 Explorers 7
B 1991 explorer build questions Modified 1991-1994 Explorers 6
1 1991-1994 A4LD transmission - Need info Modified 1991-1994 Explorers 2
G 1991/1999 compatibility Modified 1991-1994 Explorers 4
R 1991 Ranger Tranny Rebuild Modified 1991-1994 Explorers 4
R 1991 xlt rear leaf springs Modified 1991-1994 Explorers 1
P 1991 explorer slight front lift need help Modified 1991-1994 Explorers 59
T 1991 Mazda Navajo rear diff question Modified 1991-1994 Explorers 19
J 1991 Mazda Navajo LX Modified 1991-1994 Explorers 0
L lift kit on my 1991 Navajo Modified 1991-1994 Explorers 7
A 1991 4.0l Camshaft kit Modified 1991-1994 Explorers 2
N 1991 mazda navajo Modified 1991-1994 Explorers 5
C lifting my 1991 2 door explorer Modified 1991-1994 Explorers 5
R 1991 Navajo lift, performance questions Modified 1991-1994 Explorers 1
O 1991 performance heads Modified 1991-1994 Explorers 11
R 1991 ford explorer lift questions Modified 1991-1994 Explorers 3
D adding 16" tires to a 1991 explorer Modified 1991-1994 Explorers 0
B 1991 5th gear/reverse update Modified 1991-1994 Explorers 1
T My $100 X 1991 4x XLT Modified 1991-1994 Explorers 6
1 5.9L CUMMINS 12V into 1991 Explorer Modified 1991-1994 Explorers 4
fiftyfordfloored 1992 -> 1991 Computer Swap - Merits? Modified 1991-1994 Explorers 2
CJExplorer First Generation Ford Explorers (1991-1994) FaceBook Group Modified 1991-1994 Explorers 0
CJExplorer 1991 Ford Explorer Emblem to New Emblem Modified 1991-1994 Explorers 22
CJExplorer 1991-1994 Removal of Explorer Emblem Modified 1991-1994 Explorers 10
K Lowering a 1991 Ford Explorer Modified 1991-1994 Explorers 12
D SAS almost done 1991 Explorer Modified 1991-1994 Explorers 16
A 1991 Lift Kit Modified 1991-1994 Explorers 16
O 1991 explorer... Modified 1991-1994 Explorers 4
D 1991 Explorer XLT Modified 1991-1994 Explorers 19
G 1992 ford explorer XLT 4WD brake rotors Modified 1991-1994 Explorers 2
C 4WD / Low Range selector switch wiring. Modified 1991-1994 Explorers 1
S Shifting into 4wd and 4wd low range without transfer case Modified 1991-1994 Explorers 4
B 4wd swap Modified 1991-1994 Explorers 7
R Swapping my 2wd 5 speed to 4wd question Modified 1991-1994 Explorers 4
L.A.X 4wd coil seats Modified 1991-1994 Explorers 17
R 91 exp 4wd differential gear oil type Modified 1991-1994 Explorers 2
X 4WD Odd Sounds Modified 1991-1994 Explorers 5
Similar threads
