logeorge
- March 2, 2010
- Ardmore, AL
- '92 XLT
Is there a source for the intake tube that runs between the throttle body and the mass airflow sensor? Mine is patched together from parts of two using 3M trim cement and hose clamps! I used to see them on Ebay, Wish etc. but they don't show up now. I suppose I could build one from metal tubing and rubber hoses from the parts store, if I can figure out what will fit and still clear the hood and fan shroud. The set-up has to be air tight or the MAF sensor goes haywire and the thing will hardly run at all if there are any air leaks. L. O. G.
