thowe2012
- March 10, 2015
- Youngstown OH
- 1992 Ford Explorer
Hey Y'all,
Here's the situation: 1992 Explorer starts fine and runs smooth as silk for about 15-20 mins or so ... then begins to bog under load (particularly climbing a hill), and the other night, it actually stalled after a fairly long trip, and warmer outside temps; it smells lean, not rich (no fuel smell at all), and the codes I pulled (see below) seem to indicate this ... new air filter, ALL new exhaust, from manifold back, new plugs and wires, and ALWAYS starts GREAT, but begins the fail process after running for a good bit! My suspicion is the fuel pump, as I have had 2 previous vehicles (GM) with identical symptoms ... if it was a spark problem or a plugged fuel filter, would it not run bad from the initial start? Possibly a sensor? ... here are the CEL codes:
116,114,116,114 ... 172,185,186,172,185,186
I sure don't wan't it to be the pump, as this is a giant PITA ... if anyone has some insight, I would greatly appreciate it!!! Thanks Tons!
