1992 Ranger Transfer Case/Clutch Install | Ford Explorer Forums - Serious Explorations
BTRs X
Maysville, KY
'92 Explorer XL 4x4
I have a 1992 Ford Ranger with a 4cyl, 5-speed manual and electronic 4x4. Im getting ready to remove the tranny to install a new clutch and slave cylinder. Can I drop the transmission without removing/draining the transfer case? If I can do this...do I have to drain the tanny?
I have done clutches before in my Mustangs, but never a 4x4. Thanks.
You don't have to drain either, but it would make them both slighty lighter. If you're using a trnny jack, it wouldn't matter, if you're going to 'benchpress' them out and in, it might!
I've read of people (410, I think) removing the trans and t-case together as one piece, but I seperated them when I did my clutch.
If you do a search for "replace clutch", there's a couple good threads here.
Good luck!
thanks.
