trozei123
- March 1, 2015
- 1992 Explorer XLT 4x4
I have a 92 xlt that came with the 60/40 split front bench seat. i wanted to get rid of the center seat and put in a console so i would have some more storage space. first thing was a trip to wal mart to see what they had. i found a small one for about 20$. i first tried attatching it to the armrest, but i did not like the way it hung off the edge. so i made the decision that was the hardest one of all. That pesky center seat and armrest had to go.
after several hours of beating at the frame with a chisel, (if i had my dremel, it would have gone so much faster) i got the metal frame of the seat removed. i saved some foam from the armrest to stuff into the drivers seat after i hand sewed the fabric back together to make the seat look solid.
i felt puzzled about the idea of using that small wal mart console now that i had so much room. i looked in my local junkyard for some consoles. while i did like the idea of using a real explorer console, i did not like how small the storage compartment was. plus they all had a single small cup holder. i did not have much money to take the console from the junk yard, so i went home to think some more.
i noticed that walmart had a full sized van console for 30$, so i wrote the measurements down. after looking around my 19 month old son's room, i finally found the perfect hack to use my original console!
i went out to the junk yard and found an ex with the same color interior as mine (blue) and i cut out the fabric from the armrest. after i got home, i used some matching blue painters tape to wrap the fabric around a regular sized level 4 box of pampers diapers. then i got a small book to put on the floor to hold the back end up since there is a small dip in the floor.
SUCCESS!!!!
i still am working on finding a small piece of wood and some small hinges to make a lid to use as an armrest. but i am very happy with the result.
other than the console, i am trying to fix it up so that the ex is as original as i can get. i don't have a big budget, so thankfully, i am finding most of the parts i need for free. i still have some issues that came with the car when i bought it from a car lot. thanks to this website, i have fixed two of them. still have a couple to go.
Issues solved:
drivers window and rear drivers side window now operate smoothly.
brake booster needed to be replaced.
Issues remaining:
want to get 4x4 working (i found the post about fixing the shift motor, will start there)
transmission leaks slowly from front (tranny shop says it the front pump seal, but i only have enough money to just keep putting fluid in)
rear passenger window is broken (the motor cable is broken from either the top or bottom of the door)
Parts found and replaced:
Rear Window Washer Nozzle
Rear door ashtray and mounting bracket
Seatbelt extensions
4x4 control module for rear compartment
4x4 button module for dash
I am very thankful to have found this website. So much more knowledge on here than i got out of my haynes manual.
SUCCESS!!!!
Issues solved:
Issues remaining:
Seatbelt extensions
