1993 Explorer 2 Door Sport 2WD ALL new A/C problems
InTitusvilleFL
Titusville, FL
1993 Explorer Sport
I just put "ALL" new A/C parts in. I know some about A/C systems but not operations. I've restored hundreds of 1967 to 1973 in-dash Mustang and Cougar A/C systems but never installed or charged them. I've installed "ALL" completely new parts in a 1992 Mustang and 1994 Mazda B3000 but had someone charge them and didn't watch. This time I had someone do this but now exactly sure if he knew what he was doing. Seems I knew more than he did in some parts of this. We evacuated the system and held pressure so no leaks. We charges the low side to about 50 but he didn't want to go over since he says is could blow the compressor. He seemed to have a problem getting a reading on the high pressure side but finally got about 120 to 130 and told me it should be 250 to 275. The air comes out cool but not cold.
Question is... What "SHOULD" the pressures be and if the low side is correct why is the high side so low. I'm assuming it's the compressor even though it's new. The pipe part of the high side around the port is really hot. The compressor doesn't cycle and I assume that's because the evaporator isn't getting cold enough to cause the compressor switch to switch off. Any ideas what's going on???
SoHK_alumni
Tampa, FL
5.0 V8 2002 Ranger
With good air flow across condenser and radiator, you should see 35-40 on low side, 185-205 on high.
InTitusvilleFL
Titusville, FL
1993 Explorer Sport
I brought it to Tire Kingdom and they used "REAL" A/C equipment and were able to get it to 45 low and 200 high but it was still blowing just cool air and not cold enough to cycle the compressor clutch. While I was driving it did get a bit cooler but not by much. By the time I got home it was warm, the evaporator and accumulator were warm but the system had enough pressure to keep the clutch on.
Right now there is no grill or bumper on this since I had so fix a few rot spots on the radiator support, so there is no obstructed air flow for the condenser or radiator.
M 1993 Explorer Heater blowing warm air and temp gauge is all over. A/C & Heater systems - HVAC 1
D need a little info 1993 explorer ac system A/C & Heater systems - HVAC 8
D Help on my 1993 ford ranger XLT A/C & Heater systems - HVAC 3
G Had a bad day. need help on A/C (1993 Sport) A/C & Heater systems - HVAC 2
N 1993 A/C wors on 1,2,3 but not HI/MAX setting A/C & Heater systems - HVAC 10
K 1993 Ex (1st gen) A/C cooler after the engine warms up A/C & Heater systems - HVAC 2
9 1993 134a recharge done, how did I do? A/C & Heater systems - HVAC 9
R 1993 a/c A/C & Heater systems - HVAC 7
A Explorer 2006 AC compressor clutch engaging and disengaging A/C & Heater systems - HVAC 0
M Rear ac line help 2012 explorer A/C & Heater systems - HVAC 1
N My 2016 Explorer Platinum is overheating and the AC system doesnt work A/C & Heater systems - HVAC 0
S 06 Explorer A/C compressor cooling issue A/C & Heater systems - HVAC 0
K 2003 Ford explorer EB AC Compressor issue A/C & Heater systems - HVAC 0
B 2005 Explorer XLT - No lower heat A/C & Heater systems - HVAC 1
B 1995 Explorer A/C & Heater systems - HVAC 2
Conestoga Actual Radiator replacement on 2010 4.0L Explorer A/C & Heater systems - HVAC 1
D 1999 Explorer A/C stops blowing cold when I hit a bump A/C & Heater systems - HVAC 1
C 1996 Ford Explorer AC Compressor O Ring / Seal Size / Source / Part Number A/C & Heater systems - HVAC 1
P 2004 Ford Explorer XLS - A/C Clicking on Coldest Setting - Left Side of Console A/C & Heater systems - HVAC 1
O 1992 Ford Explorer XLT Compressor issues A/C & Heater systems - HVAC 5
R 97 explorer 6cyl ac vacumn hose location A/C & Heater systems - HVAC 0
S 1994 Explorer XLT AC leak... A/C & Heater systems - HVAC 2
T 1996 Explorer AC Clicking A/C & Heater systems - HVAC 1
M 2014 ford explorer limited with rear ac A/C & Heater systems - HVAC 0
0 01 explorer blower motor won't turn off?????? A/C & Heater systems - HVAC 0
B 99 Explorer A/C Clutch will not engage A/C & Heater systems - HVAC 3
P 07 explorer, is it the blend door or is it the actuator A/C & Heater systems - HVAC 1
T 2004 Explorer Limited - Replacing HU A/C & Heater systems - HVAC 0
Y 98 explorer won't blow cold air! A/C & Heater systems - HVAC 0
R 08 explorer air conditioner help A/C & Heater systems - HVAC 10
D AC in 2010 Explorer A/C & Heater systems - HVAC 1
G 2005 Explorer AC not working A/C & Heater systems - HVAC 0
S 2001 Explorer AC Problem/Question A/C & Heater systems - HVAC 1
B 98 Ford Explorer A/C issues A/C & Heater systems - HVAC 1
K 01 Explorer Sport A/C & Heater systems - HVAC 0
F HVAC Troubles / 2000 Explorer XLT A/C & Heater systems - HVAC 0
T 2001 Explorer Sport 4.0 SOHC Vents stuck on. A/C & Heater systems - HVAC 1
D 99 Explorer Sport A/C Blowing Hot Air A/C & Heater systems - HVAC 1
S 98 Explorer A/C Clutch problems A/C & Heater systems - HVAC 1
P 2001 EB Explorer A/C Leaks 6Cyl SOHC A/C & Heater systems - HVAC 0
T 2005 Ford Explorer AC only Coming out one Vent A/C & Heater systems - HVAC 0
B Need a blend door cable for 1991 Explorer XLT A/C & Heater systems - HVAC 0
M 04 Explorer no heat A/C & Heater systems - HVAC 1
P 2006 Explorer XLT 4.0 Temp blend door fix ? A/C & Heater systems - HVAC 0
T No heat 1997 Explorer. A/C & Heater systems - HVAC 0
P 02 Explorer - Air/Vent control won't work A/C & Heater systems - HVAC 0
J Ford Explorer 2006 A/C not blowing at front A/C & Heater systems - HVAC 3
D New a/c lines 98 ford explorer 4.0 sohc A/C & Heater systems - HVAC 1
S A/C not cold. 2001 explorer A/C & Heater systems - HVAC 3
D 98 explorer blower stuck on high A/C & Heater systems - HVAC 3
Similar threads
