woknap
- June 19, 2014
- Ocean Park, WA
- 1993 Ford Explorer xlt
Hi, I messed up and broke the left front intake manifold bolt, but that is not what my question is about. When I removed the other bolts, the manifold and then the gasket, it seemed like the sealer they sell with the gasket for front and back edges was not "touched" or squeezed. I am worried now that if I had not broke a bolt, the manifold would not have been sealed good where it meets the block in front and back. I guess I used about a 1/16th" on each surface, but will try 1/4" this next try. I was torqued down to 192in-lbs.
The water jacket areas seemed to have been sealed good.
What about using the intake manifold gasket over? It was on there for about 10 minutes; should be ok to reuse?
Thanks
Greg
Thanks
Greg
